Originally Posted By: 95busa
All- thanks very much for the input. I decided to run with the 4.56s- if it was a daily driver I would probably run the 4.10s, but since it is really only run over about 10 miles when I am towing, hauling, or hunting I think I am OK accepting risk on high RPMS, which seem like they would only get on the high side with OD locked out. I appreciate the heads up on the pinion speed/cooling issue. After break in I will run a Mag-Hytec diff cover with Redline or Amsoil 75w-140 in order to mitigate those potential problems.
I'm assuming it's an auto transmission? You'll need a programmer to adjust the speedo. A good custom tune either way will help wake things up. SCT xcal3 from VMP tuning or Troyer Performance are very good options for that.
