I have a 1999 Toyota Camry with a 5S-FE motor that I recently did a timing belt, water pump, and oil pump seals job on over last weekend. The oil pump seal was a bit leaking, and after removing the oil pump I found the previous job from ~10 years ago had used the spaghetti rubber gasket and also smeared permatex grey around the seal. See pictures below. I removed that and used a new spaghetti rubber seal and just some shin-etsu silicone to hold it in place. It leaks much more now, like a drop a second at 1000 rpm, and increases with rpm.
You can see the line of RTV around the outer housing.
You can see the bits of grey permatex that were stuck around the inside rim of the oil pump it from the last job. Gross! The last installer was very messy with it!
So I ordered in a can of Permatex Ultra Black in a power bead can. I was thinking of just laying a bead to fill in that groove and trying that? Do you think it would be effective at sealing the oil pump, with all due caution taken while sealing it? Here's a picture of the can:
