- Joined
- Mar 19, 2026
- Messages
- 9
Hello ya all. Too many different and conflicting AI search answers for this. 2006 series III 3800 oil pump prime issue (Buick Lacrosse cx). Vasoline, fill oil filter, fill sensor hole, and pump still not working. Worked just fine before changing torque converter though. Yeah, I mistakenly took off the oil filter housing listening to a few vids to get the job done. So, what really is the simplest way to prime the oil pump? Or, is there the slightest change the hardly noticable curvature in oil pan from jacking engine a bit has messed with the oil pump pickup tube filter? Dropping the pan to investigate is the last option, however, do I need to do it? I ask because the engine needs to be raised a little and subframe lowered a little just to wiggle off the pan- not so fun and quite time consuming.
