Changed my mind. Stickin with the 0W20 and BG PN 115 additive as usual. If if ain't broke, don't fix it. 3K OCI's
That is correct. These engines as with any can handle higher grade oils with no problems. They all, including standard run of the mill, can accommodate a wide range of oil grades with no adverse affects besides fuel economy (even though the fuel economy degradation will most likely be unable to be noticed without a lab running tests) . But back to reason for this post is yes a higher grade oil can and will be the easiest way to slow consumption short of re-ringing and a valve job.Yes, but high performance engines have more need of thicker oil. Daily drivers not as much, if driven normally. Also, I doubt that Ferrari, Porsche, or Lamborgini cares about gas mileage.
I agree that going up 1 grade is an easy patch, but first I'd replacing PCV and possibly also crankcase breather hose and try Valvoline Restore and Protect in normal grade for 1-2 oil change intervals. If it's still guzzling oil, then try Valvoline Restore and Protect in next higher grade for 1-2 OCI.That is correct. These engines as with any can handle higher grade oils with no problems. They all, including standard run of the mill, can accommodate a wide range of oil grades with no adverse affects besides fuel economy (even though the fuel economy degradation will most likely be unable to be noticed without a lab running tests) . But back to reason for this post is yes a higher grade oil can and will be the easiest way to slow consumption short of re-ringing and a valve job.
Recall what HPL typically goes for either 1 quart or a container of 5 quarts?Mobil 1 ESP 0w-30. ESP is their Emissions System Protection line (mid-SAPS oils).
HPL is High Performance Lubricants, considered by many knowledgeable people to be the best oils you can buy at any price.
Interesting, I’ve used 15W-50 in my EA888 2.0 and noticed zero difference in acceleration nor oil temperature. The Audi 1.8 must be quite different. I did this to see how it affected oil consumption in the engine. I left it for the whole OCI so I did have some time with it in the engine.
I think it depends and I've posted this observation before. I had an Audi A4 1.8T Quattro from new in 1997 until 2005. It called for 10w30. I used Mobl1 10w30 after the warranty expired. For some reason I bumped that up to 15w-50 around June 2004 at about 135K miles. Big mistake - huge!
This car had an oil temperature guage; the oil temperature shot up 30-50 F on this thicker oil. Acceleration was sluggish as well. After a two day weekend running five hours per day I dumped that oil and went back to 10w30.
My take away here is that you might consider bumping it up one grade but not two.
You're correct about grade being the correct term, but does it really matter? We all know what he meant. BITOG is the only place I ever heard people correct others over it.
To respond the question of higher viscosity in higher mileage engines:
You can’t really band-aid something wrong with thicker oil. If your bearing clearance is huge because they are worn drastically, the even 20w50 won’t fix that. Yes, you’ll have better oil pressure but you’ll still have very short life left because the roached surface finish of a bearing that badly worn would need more than a couple points more cSt to establish full hydrodynamic lube.
If an engine has made it to high mileage with little to no consumption, why not stick with that?
That’s kind of the catch-22 with going thicker on oil just because the engine is old. Either its old and in great shape, which suggest going thicker is unnecessary. Or it’s old and in rough shape, which cannot be helped by thicker oil.
If the bearings are roached, the time to go to thicker oil was years ago.
https://www.advlubrication.com/collections/passenger-car-lubricantsRecall what HPL typically goes for either 1 quart or a container of 5 quarts?
Short answer: no. If the car runs fine leave it alone.There are various weights of oil, of course. Is there an amount of miles on a vehicle where it is a good idea to jump up a weight in oil?
In other words, is there a certain amount of miles where to get the same function from the weight a person was using, that person needs to go up in weight?
Hypothetical example: The manual says 5W20 or 5W30 should be used. After 150K miles, does a person need to jump up to 5W40 to get the same effect that the previous oil provided when the car was newer?
Sure. On the other hand, a 20-grade is on the cusp where increased wear occurs unless there are design changes to the engine.Short answer: no. If the car runs fine leave it alone.
Longer answer: if your car is serviced at a reputable shop, they will not want to deviate from the factory recommendation so unless you are doing the maintenance yourself expect some pushback on using an oil different than specified. Not just engine oil, but driveline fluids, transmission fluids, etc.
Final consideration: many people consider the lower viscosity oils to be some sort of conspiracy. But the reality is, and I say this as someone who is not an exactly a fan of the EPA’s meddling in fuel economy, is that the average age of a car today is older than it has ever been. Lower viscosity oils like 5w20 have been mainstream for close to 20 years and we are seeing this record longevity (maybe in spite of EPA meddling) and so to draw a conclusion that modern engines cannot properly function for a long time is not a conclusion that is supported by the longevity data we see. It is popular to say in enthusiast circles that “new cars suck” relative to some golden age, but the reliability and longevity data in general belies this claim. The proper analysis focuses on following the maintenance requirements of your car and using quality parts, including motor oil, with any repair or maintenance procedure.
Have a good day.
Ok: Here's the breakdown. Every 3k, this 13' CRV, with 614,877mi gets EPR 109, drain out till no drips, new filter ( usually OEM ), new crush washer. Then in goes the 0W20 with BG PN 115. Daily driver, it's just tired, no roached bearings. I'd be tired too. Is the PN 115 helping longevity ? Using 20k synthetic oil. Yes, to many, this seems like at waste of $$$$$$.....But, it's only about 2 OCI's a year since we alternate cars. 6 months on the CRV, 6 months on the 03' Solara. Wifey uses them for work, food shop, pharmacy, etc. I''m retired and just putz around the house, maybe go to the orange store for something, get gas for the lawn equipment. Wifey's round trip from work is 26 miles. So, the CRV is really only run 6 months a year, in the cooler months ( Oct-Apr ). So, it's a bi-yearly cool weather daily driver. She picked those months because of the AWD for the snow. So, will 0W20 with BG PN 115 suffice with the cooler temps she uses the thing for. Basically it sees 6k on the ODO a year, that's it. The mileage got that high when I was working, and using that car/truck/or whatever it's called. Have the internal hemmoroid's procedure to prove it. LOL
... Man..that recovery HURT !!!!!!!!!
Exactly.The 0W-20 will be fine by itself. The BG is just making your wallet lighter. BG 115 has a KV100 of just 7.7 cSt (likely lower viscosity than your 0W-20) with a pour point of just -25°F and flash point of just 355°F. That's making your oil worse. Ditch it.
It's highly unlikely that your oil needs or benefits from a supplement. If your oil actually needs a supplement, you're using the wrong oil.
Get out !!!! So BG PN 110 or 115 is all B.S. ??????
Get out !!!! So BG PN 110 or 115 is all B.S. ?????? It actually THINS the oil ?!?!...What good is that ????? No good in my book. Are there any additives that work ? Or are they all snake oil....I was hoping the 115 was keeping the oil from degradation. Guess not![]()
