UOA Honda Vs AMSOIL
Ontario, Canada
Hi, I am a new member and I am posting my oil results from my 2008 Honda Ridgeline. I have always used Honda oil filters for the 4 years I have had it. I recently tried an AMSOIL filter and the results seem much better. I wanted so see what others thought. This is with regular non-synthetic oil. I plan to try AMSOIL synthetic on my next oil change. Please note that I am an AMSOIL dealer and I was just doing this as an experiment for my own knowledge. Both oil changes were after 11000km (6800 miles) as suggested by the maintenance indicator. Driving habits are basically the same. Analysis by Blackstone. AMSOIL HONDA Aluminum 6 11 Chromium 1 2 Iron 19 47 Copper 3 4 Lead 0 1 Tin 1 2 Molybdenum 1 2 Nickel 0 0 Manganese 0 1 Silver 0 0 Titanium 0 0 Potassium 0 2 Boron 19 3 Silicon 18 22 Sodium 118 249 Calcium 1801 1403 Magnesium 12 9 Phosphorus 582 591 Zinc 641 762 Barium 0 0 Viscocity SUS 50.2 48.9 Viscocity cST 7.32 6.92 Flashpoint 335 370 Fuel % 1.0 <0.5 Antifreeze % 0 0 Water % 0 0 Insolubles % 0.3 0.4 TBN 2.1
It's hard to compare filter performance when it at least appears that the oil also changed. The concentrations of additives appear to be different between the two samples (Sodium, Calcium, Zinc). Was the motor oil the same with both samples?
Originally Posted By: hotrod66
This is not what it looked like before I posted it.
You can use the "code" tag (in brackets) to force it to use your formatting.
Code:
		AMSOIL	HONDA
Aluminum 	6	11
Chromium	1	2
Iron		19	47
Copper		3	4
Lead		0	1
Tin		1	2
Molybdenum	1	2
Nickel		0	0
Manganese	0	1
Silver		0	0
Titanium	0	0
Potassium	0	2
Boron		19	3
Silicon		18	22
Sodium		118	249
Calcium		1801	1403
Magnesium	12	9
Phosphorus	582	591
Zinc 		641	762
Barium		0	0
Flashpoint	335	370
Fuel %		1.0	<0.5
Antifreeze %	0	0
Water %		0	0
TBN 		2.1
Hopefully this works: [code] AMSOIL HONDA Aluminum 6 11 Chromium 1 2 Iron 19 47 Copper 3 4 Lead 0 1 Tin 1 2 Molybdenum 1 2 Nickel 0 0 Manganese 0 1 Silver 0 0 Titanium 0 0 Potassium 0 2 Boron 19 3 Silicon 18 22 Sodium 118 249 Calcium 1801 1403 Magnesium 12 9 Phosphorus 582 591 Zinc 641 762 Barium 0 0 Viscocity SUS 50.2 48.9 Viscocity cST 7.32 6.92 Flashpoint 335 370 Fuel % 1.0 <0.5 Antifreeze % 0 0 Water % 0 0 Insolubles % 0.3 0.4 TBN 2.1
You need to close your opening tag by putting in a closing tag with a forward slash - [/code]
Code:
Like this - I have both the opening tag and a closing tag with the forward-slash as demonstrated above
Interesting. I have never seen a Honda filter increase, or reduce wear. Were the oils the same? During what season were these OCI's? Im not convinced the filter lead to the higher wear.
What type of oil did you use (grade and brand)? Was one UOA done in winter, and the other in summer? Maybe cold starts could account for the high Iron? In your Canadian climate, I'd be experimenting with viscosities (e.g. 0w20 syn) before I worried about filters.
I would like to see some head to head single pass particle count efficiency tests (independent of course) of amsoil EAO vs. Fram Ultra. As well as time test with dirt holding capacity vs. efficiency over time... I think EAO's are still the best filters for long OCI, just IMO. But I could be wrong.
