DIRK: From what we can see, this Castrol blend did just as good a job as the previous Pennzoil platinum. Actually, iron (from steel parts) is reading a little lower than before -- this level is more on par with what we were seeing back in 2012 and 2013. Not that the 25 ppm from the previous fill was a problem, but since iron came down on a longer oil run, the wear-rate (ppm/mile) was better this time around. No dirt, moisture, or any other contaminants were detected, and the TBN is good at 2.4, so the oil had active additive remaining. Try 9,000 miles next. Nice report!
OIL CASTROL 10w30 SYNBLEND
MILES IN USE 7,343
MILES 208,038
SAMPLE TAKEN 9/30/15
ALUMINUM 5
CHROMIUM 1
IRON 16
COPPER 4
LEAD 4
TIN 0
MOLYBDENUM 14
NICKEL 2
MANGANESE 0
SILVER 0
TITANIUM 0
POTASSIUM 2
BORON 20
SILICON 19
SODIUM 32
CALCIUM 2456
MAGNESIUM 12
PHOSPHORUS 717
ZINC 824
BARIUM 0
INSOLUBLES 0.3
WATER 0
FLASHPOINT ºF 415
SUS VIS 210ºF 63.3
cSt @ 212ºF 11.15
TBN 2.4
I am actually very happy. . . . iron dropped to 16 from a prior 25
MILES IN USE 7,343
MILES 208,038
ALUMINUM 5
CHROMIUM 1
IRON 16
COPPER 4
LEAD 4
TIN 0
MOLYBDENUM 14
NICKEL 2
MANGANESE 0
SILVER 0
TITANIUM 0
POTASSIUM 2
BORON 20
SILICON 19
SODIUM 32
CALCIUM 2456
MAGNESIUM 12
PHOSPHORUS 717
ZINC 824
BARIUM 0
INSOLUBLES 0.3
WATER 0
FLASHPOINT ºF 415
SUS VIS 210ºF 63.3
cSt @ 212ºF 11.15
TBN 2.4
