Quote:
I'm changing the transmission filter and adjusting the bands in my 1994 Dodge Ram Cummins diesel truck with the 47RH transmission. I'm thinking about refilling with universal tractor transmission fluid rather than the standard red ATF. It seems to me that any transmission fluid that will work with wet clutches should work in an Automotive transmission... and many tractors see far more severe conditions than most on road transmission applications. How well do you think this would work ? Thanks.
An UTF (typically of 5W30 grades) would work fine in torque-converter type auto transmissions.
In relation to a typical Dexron III, it provides higher MOFT (i.e after shearing).
The bearings and gear sets within would love the extra AW additives from UTF.
Overall, components longevity may improve .... but surely not subpar.
Quote:
I did it on my company work van and it seemed to work. But then the van wasn't mine. I also wonder if the tractor would be a better oil for manual transmissions that suggest ATF.
Maybe valid for components wear protection, but synchronizers might hate its FM ...... more so some UTF's are without appropriate "GL4 FM' .
There is a chance some synchronizers might be picky on some UTF that comes with GL4. Not all UTF are GL4's.
In terms of components wear protection, UTF is generally stronger than a typical ATF.
