Ive had great luck with Universal Tractor Fluid #134 as a replacement for (unobtainable) Mopar #10 Fluid Drive Fluid. I like it better than the Type F ATF some use.
Anyone else with a old Fluid Drive Mopar? If so what fluid have you had success with.
(A Fluid Drive is a conventional transmission fitted with a fluid coupling similar to a torque converter in addition to the clutch. It was in pre and post war Mopars).
