I want to use Amalie Universal Synthetic Automatic Transmission Fluid in 99 Camry Power Steering system. I had purchased Power Steering fluid from local Federeated car parts store but reading some internet material, I came to conclusion that I would be better off using ATF as that is what is listed on the PS reservoir cap. People of have suggested synthetic ATF (actually Mobil 1 ATF) but this is what the store carries.
Link
Amalie Universal Synthetic Automatic Transmission Fluid is a full synthetic automatic transmission fluid and is now reformulated with even more universal applications in modern traditional Automatic Transmissions. It is by far the most dynamic member of Amalie’s family of high performance automatic transmission fluids. It is the latest iteration of the fluid that changed the ATF market – the one premium ATF that became known for its rugged dependability, and as the inventory optimizer. With the exception of CVT fluids and Duel Clutch Fluids (DCT), the new Amalie Universal Synthetic ATF will come with broader and more universal coverage for the more traditional planetarygear transmissions. By separating out the CVT application, Amalie is able to endorse performance applications for many more European, Korean, Japanese and U. S. heavy-duty transmission applications than ever before – not just the newer and more demanding transmissions, we are now able to recommend Amalie Oil Company’s Universal Synthetic Automatic Transmission Fluid for all conventional automatic transmissions – old and new. It is a special blend of synthetic base oils coupled with a multi-functional additive system and advanced friction modifiers to provide unsurpassed protection and reliable performance for all types of automatic transmissions, power steering units and hydraulic systems manufactured by virtually all of the automotive and transmission manufactures from around the world – the one fluid that replaces the confusion about which fluid to use in a multitude of automatic transmissions. Amalie Universal Synthetic Automatic Transmission Fluid is such a superior transmission fluid that it may be used wherever established fluids are required or specified by all OEMs around the world including but not limited to General Motors approved Dexron® fluids including Dexron® VI and GM T-IV; Ford Motor Company's Mercon® approved fluids including Mercon® V, Mercon® SP and Mercon® ; Honda ATF-Z1, VTM-4, DW-1, DPF, Mercedes Benz, Mitsubishi Diamond SP
Link
