I'm a real mechanic.
Piston rings can be dried out and score the cylinders and seize in the lands.
Bearings can be wiped out quickly. this can be a rod knock that goes away when revved up, or a perpetual one.
I'd use a light oil down the plug holes, and let it sit for awhile. Prime the oil circuit by a drill or by cranking the engine over with the plugs out[if that's all you can do].
Maybe add 1/2 qt extra oil for various splash lube points.
Then start her up.
Then start her up.
