My Basketcase Wrangler YJ Won't Start
Central NY
It was a bad buy, I regret buying it entirely.
This is in an 89 Wrongler. Originally a toilet bowl 258, it is a 4.0 swap. Someone HACKED THE WIRING TO DEATH doing this swap in the worst possible way.
Computer is from a 1994 XJ. As is the PDC/Fusebox under the hood. Relays are all new so I suspect they had been having problems before. It started and drove into the garage for me to weld the frame (battery disconnected). Now it won't start. The fuel pump is wired to key on, so fuel at the rail is a bad test. I bought a computer on ebay and am waiting on that to come in.
Some info on what is / isn't happening
- Fuel pump relay does not click , ASD relay does not click.
- Fuel pump relay will click / turn on if I ground where pin 85 on the ASD relay goes in the PDC (with the relay removed)
- I checked a few sensors and I am getting 5v to the sensor when I turn the key on
- There is an upstream Oxygen sensor
- I do not see a downstream oxygen sensor
- I jumped pin 87 to 30 and it still won't run.
- The 15A ignition fuse does come on and off with the key
- Pulled a plug and it does not smell like gas, definitely no injector activity.
- Checked for spark, none.
I don't have any sort of shop scope or any way to check waveform on the CPS to see if that's actually working.
Where should I head next? The Tac and all gauges on this are analog so I do not have any ability to check the check engine light codes or whether or not the tac moves while cranking.
Another option - and one I really don't want to go with - is a 258 aluminum intake and standalone HEI.
  • Like
Reactions: Arc
A '94 (or at least the brains) should be OBD I. Is there a key dance you can do to make the CEL blink out a code? (E.g. One long flash followed by three short ones would be a "13" code, which would mean something in Jeepanese.)
I spent a lot of time this week checking on stuff. There's a lot of cut wires but nothing important is cut. When I turn the key on, the computer is commanding the ground for the ASD relay. That can mean a few things - 1) bad crankshaft position sensor 2) bad computer.
So it's not trying to prime the fuel pump when starting (even though it's wired to key ON, it should still be playing with the relay) . There's still some confusion with a ballast resistor (which neither an 89 wrangler or 94 cherokee would have ...) powering the pickup coil / cam sensor.
I put a new crank sensor in it and still no start. But I don't trust the cheap crank sensors. It also doesn't help that it only had ONE BOLT holding it in. Snagged a new one at the junkyard. But it still wasn't trying to prime when I turned the key on.
Computer came in today and it started right up.
89 wrangler didn't have a ballast. An XJ will
The computer / electronics are from a 1994 Cherokee.
I know an AMC-XJ would have a ballast resistor. Possibly a Renix TBI 87-90 2.5l Wrangler.
I think this had computer problems before I bought it. The more I think about it, I think a lot of stuff was done out of desperation to make it run. They had the ASD almost completely bypassed. The fuel pump and coil were getting power incorrectly.
  • Wow
Reactions: D60
Seems like a PITA, but I had to laugh at your amazingly accurate description of "basketcase"
Good luck!
You should do what Thunderhead289 did and just convert to a carb. Although I'm not sure I'd recommend that carb...
At this age does it has to pass any sort of emissions requirements? Does sound like you're getting past the electrical issues though.
