Hey all, about a year or so ago I had a crankshaft position sensor go out so I had it replaced, but they did it with a non-OEM part. a couple months later it wouldn't start again all of the sudden. I assumed it was because they used a cheap sensor instead of OEM and it went bad again, so I provided the OEM Honda part and had them replace it but before they could the car magically started working and starting again. Nonetheless, I had them change it out to the OEM part anyway
Fast forward to now, and it won't start again. I took it to a different mechanic this time and told them my story. They want to start with changing the spark plugs and charge me $375 to do it with the potential of it costing more if the threads get damaged. But the thing is, the car was running fine the day before and then I went to start it in the morning and all the sudden it just wouldn't start. Is it really possible all 4 plugs just go bad at once like that? I mean it fires a little bit when I crank but not much, battery is strong. The mechanic said that yea they can all go bad at once like that especially if it sat over-night and it was cold and the cold temperatures changed the gap of the plugs. Also, $375+ to change plugs on a 2009 civic?
