As many of you likely saw, I decided to do a 2 vehicle test on Valvoline Restore and Protect 5w30 in a previous thread. One of the test subjects was my 1990 Acura Legend with a lifter tick only when cold and visible carbon and varnish buildup while the other test was on my friend's oil burner 2010 CRV. Since the results weren't what I hoped for, I decided to try another product. Here's a link to the Valvoline Restore and Protect test thread for those who haven't seen it https://bobistheoilguy.com/forums/threads/2-valvoline-restore-protect-tests.384060/
As a quick summary, on my Legend, I just added a quart of EC30 today and I'm looking for a reduction in cold lifter tick and/or a visible reduction in the carbon and varnish buildup under the front valve cover. For reference, here's the front head at the start of the EC30 test.
My friend's CRV doesn't have any abnormal carbon/varnish buildup, but it does consistently burn about 1 quart of XW-30 oil every 1K miles, which is most likely due to stuck rings and clogged oil drainback holes (a known issue on that era of K series), but in fairness to all products being tested, the actual cause isn't known for sure since the engine hasn't been torn down for an inspection. Either way, a decrease in consumption would be nice to see.
Anyways, I'll keep this thread updated for the duration of the test. As always, any thoughts or suggestions are welcome!
