Thanks for the information. I understand more now. I checked the OM and it only allows 0w20.
As usual, the owner's manual creates ambiguity. What it says is:
Recommended viscosity: SAE 0W-20
That is the base recommendation, everything else on that page flows from that statement. So in reality it "allows" any grade you wish to use. It subsequently says "An oil with a higher viscosity (one with a higher value) may be better suited if the vehicle is operated at high speeds, or under extreme load conditions" so that right there is an open door to use whatever you like. What if I determine the definition of high speed is anything above 60 MPH? No where in your owner's manual or the warranty book does it say that your new-car warranty is predicated on a particular grade, does it?
The bottom line is that the owner's manual does not only allow 0W-20. For a specific reason they wish you to think that but it isn't the case.
