Dexos 1 Gen 2 or API-SN PLUS?
South Dakota
I've noticed more synthetics on the shelf lately finally with the SN-PLUS certification. I have a 3.5 ecoboost I tow regularly with, so I'd like to use the best oil to avoid LSPI but which spec should I be concerned with? I read dexos 1 Gen 2 has an LSPI test, but have Quaker State Ultimate Durability on the garage shelf that is gen 2 certified but not SN PLUS.
dexos 1 Gen 2 and SN+ both address LSPI. GM came out first then API came out with the supplemental SN+, which I believe tests to the same Dexos1 Gen 2 testing protocol for LSPI.
They both address LSPI but dexos 1 Gen 2 is more stringent in other areas where as SN Plus is solely a supplement to SN and only addresses LSPI.
There are Conventional oils that meet SN Plus. None, to this point that meet dexos 1 Gen 2.
I would just worry about Ford's own spec since those oils will also protect against LSPI, Motorcraft and others meeting SN Pkys.
According to my Lubrizol chart, Dexos 1 far surpasses SN+ in wear, sludge and fuel economy. They are about the same in piston deposits and oxidative thickening.
It appears that overall, Dexos oil would be the better oil based on Lubrizol's chart.
I know nothing about how it relates to LSPI.
