trop artic in old ford
nebraska
hello all ! I have a new to me 1988 ford f150 302v8 c6 2wd 3.55 8.8 rear
and have a question that may have been beaten to death, with the talk of zddp in oils and my 302 not having a roller cam in it yet . Will a engine oil such as $1.99qt -trop artic 5w30- meeting newer sn standards, matter after years of "break in" . In other words , will this work well in my application below 0*F winters 90+*F summers?
At what oci should I run 3000 winter 5000 summer? or yearly in which my last truck never got over 3000miles a year
as a side note I do know that it was used and abused by previous owner aka mabe had oil changed once a decade lol
I would use the TA with confidence. If you put on 3k/year, then yes, an annual OCI will be fine.
You have stock (weak) springs. The fact that it is flat tappet is of no consequence, any basic 5w30 is more than adequate for that low-stress setup.
Originally Posted By: Chris142
Didnt ford go to roller cams in 1986? Regardless they are using other anti wear addatives and a stock flat tappit cam will be fine
They probably had flatties in about the '91 F-150 and the changeover was sometime around '92. give or take.
Still the weak valve springs allowed you to use about any oil.
I believe the change to roller lifters took placed in 85.
(I believe the change to roller lifters took placed in 85.) Yes, In the Mustangs and Capri's, LTD's in about 1988-89, The 5.0 F-150s no Rollers untill 91-92 The 5.8L (351W) no roller cam until 'around" 1995. I rebuild alot of these engines for race/Street upgrades.
Sure, for the Mustang and possibly some other passenger cars. Now maybe somebody put a passenger car engine in the truck...
Carbed(only, not CFI) Stang was first 5.0 with roller in 1985, in 1986 ALL 5.0 passenger car engines used roller cams, includes Lo-Po Crown Vic, T-Bird etc... AFAIK no truck 5.0 used a roller cam prior to switching to mass air in '94(def not before '92)... 1994 is also first year for any 351 to use a roller cam...
Exactly. I wouldn't even worry about using a modern oil unless you have a 1970 or older muscle car with a flat tappet solid lifter.(not hydraulic)
In the vulcan V6 3.0L, 183 c.i, was like 1993-1994.
I wasn't exactly sure of the dates..and I guess some of the posts are getting nit-picky. Perhaps a contest to see who has the most Ford-smarts?
ANYWAY, RockAuto shows both flat and roller lifters for the '92 5.0 F150 and all replacement lifters are roller for 1993 F150 5.0 engine.
Though if it makes you feel better we'll say that your info is the most correct.
IMO your plan sounds fine, absolutely no worries going 1 year/only 3000 miles on Trop Artic.
Agree with you, but also TFB1; the Mustang got the roller cams first, followed by the F150 a few years later (I don't know the date).
looking at the data sheets ( voa and others ) I don't know how good this oil is at cleaning
(side note) what I DO know is previous owner did 0 maintenance , oil leak at valve covers ( caused a crack in a ex. manifold) , coked intake and egr , pcv (well, nobody usually know where that is) , mismatched plug wires blackest oil I ever seen , oh and the rear tank was full of bad racid nasty gas I ever see and smelled
well, Kuato ,that is just the half of it .
coolant system , transmission, rear etc. brakes
never want Pennzoil conventional in this vehicle , ( I did work at Iffy ( umm... a lube shop ) until recently
I have seen what it does ,eyes are no lies
ok, BITOG .... rant over
might try Rotella 10w30 for an interval to clean it out a bit more ( I some for any other truck ,but it was totaled )
Then don't use Rotella. Same company, same chemist, although I believe your eyes and noggin needs a refresh or reboot.
I love how myths are believed over real numbers(TBN, NOACK, HTHS, etc)...
No one here is going to convince me any one conventional API GF5 SN oil has a clear advantage in cleaning vs another...
I bought a neglected '96 F-150 three plus years ago that had not seen a change in who knows when(had less than a quart in pan)... Only thing I can say was a plus over the OP is at least both tanks worked(I've since repl rear pump and it really needs the front)...
All I did over a couple weeks before it was licensed was run it a few times in the back yard with three fresh odd quarts of oil I had on hand... Was then drained(was nasty) and Quaker State Conventional used for it's first change of 4K... That oil was color one would expect after a 4K run in a 179K engine... The drains since have also had approx same appearance, so if engine is sludged, it's apparently not being cleaned... Runs fine, so I don't really care...
well, Rotella is a diesel rated ( duel rated) oil , very good cleaner and very good anti wear , ( used it in the other truck after it was totaled I looked under the valve cover it was 10x cleaner than when I got it )
I don't know if Pennzoil conventional cleans so well it looks bad , it's additives fall out of suspension , or most newer cars are sludge prone
my eyes , and my noggin are so far ok , was lower bay , 1 truck had a jellied up filter should have took pics
