I have a 1978 Trans Am and I am looking for an oil brand and viscosity
recommendation. Note, my Trans Am is not stock. I have added a stroker 455 crank to the original 400 and engine was completely rebuilt with
Comp Cams hydraulic roller lifters (stock was hydraulic flat tappet lifters) - therefore, I don't think I need an oil with high Zinc/ZDDP.
This is car's specifications:
1978 Trans Am, 400 Block / 455 stroker crank, forged rods and forged pistons, Ported cast iron cylinder heads, 9.3:1 compression, after market (Competition Cams) roller camshaft/roller hydraulic lifters, likely puts out around 450hp/500ft lbs torque...redlines around 5500rpm,main and rod bearing clearances are .002-.003, 3.42 rear axle, 4 speed Borg Warner Super T10 Manual Transmission. I have about $9,000 invested in the engine
I will generally only drive the car on weekends and I will likely put only a few thousand miles on each year. Summer temps are around 80-85F. I will generally drive the car in nice (above 60 degree F weather), though will likely start/drive engine/car on cool fall nights and I will start/drive the card a few times during the winter when around 35-40F. I can change the oil frequently.
I am not too concerned about the cost of the oil. Though, I like to get good value for money spent. I have read a little about oils like Amsoil, Royal Purple. These oils seem a bit pricey around $10/quart. I am not sure are they worth the higher cost. I am bit confused about using a syntethic oil. I use synthetic oil now exlusively in my newer cars. But, I have read that some have problems (perhaps seals/gaskets leaking a little when using synthetic oil in these older muscle car engines). I have read that synthetic blends may offer better start up protection without some of possible negative side effects (ie. possibly leaking seals/gaskets).
I most concerned about protecting the engine from a spun bearing
and avoiding problems with the thrust bearing.
Given the above , can anyone recommend an oil brand and viscosity
and perhaps say why you would recommend that oil ? Thanks
