He is using his daughters '23 Corolla as test bed. Also mentioned how 10,000 mile oil changes are not a good idea and that he changed the oil twice already himself before taking it in to the dealer at 10,000 miles to see what oil they will use.
Not really but I’d rather rely on an intrinsic property rather than the additives. But maybe that’s just me.I found it interesting when he shared what was learned from trials at GM, that a 0W-12 resulted in less wear than a Gen 2 Dexos 1 5W-30, showing that additive package can make enough difference, so that a thinner oil can protect better than a thicker oil. This sure goes against the grain of a lot of personal opinions shared here.
Do the two oils have the same additives ? If not, it's not a valid comparison, is it ?I found it interesting when he shared what was learned from trials at GM, that a 0W-12 resulted in less wear than a Gen 1 Dexos 5W-30, showing that additive package can make enough difference
Will this shut up the criticisms of "thin" oil and extended intervals ? Sadly, it won't....
Also my stance, and why I'll continue with my 1 year/<2k mi (Mazda MPI) and 6mo/<2k mi (Hyundai GDI) service intervals. Oil's cheap compared to a motor. Always Mobil1 HMFS oil for both.His position is that oil changes are cheap in the grand scheme and don't really have much downside (if you can manage to avoid stripping the drain plug) if equipment longevity is a goal.
Why does someone have to be shut up? Perhaps make valid technical arguments instead.Will this shut up the criticisms of "thin" oil and extended intervals ? Sadly, it won't....
Lots of common wally world xw-30 oils are barely 10 cSt at 100C. That criteria really thins the herd. Not criticizing as the thinnest stuff on my shelf is 10.6.What is there to discuss?
If the oil is thinner than 10cSt at operating temperature, no.
If it's thinner than 7cSt at operating temperature then heck no.
In that case, vanilla SAE-30 is good stuff. Maybe we depend on both. For instance, ZDDP is an additive that we're all familiar with and gets lots of love. I think we rely on both.Not really but I’d rather rely on an intrinsic property rather than the additives. But maybe that’s just me.
To his credit, he was pretty clear that this example GM xw-12 was a boutique formulation in terms of anti-wear additives, not representative of things available on the retail market. I think his point in the example is that physical lubrication and chemical lubrication are a give and take. Each can give, each can take.Do the two oils have the same additives ? If not, it's not a valid comparison, is it ?
The vast majority argue against thin oil / long intervals and give ZERO technical arguments. All too often they're just repeating things others said (with no technical arguments there either). Plenty of examples of Toyota owners/engines following the spec'd oil (0W-20 and lower) being changed every 10k miles and they still last 200k+ miles while some claim a conspiracy that the automakers only want to squeak by the warranty time.Why does someone have to be shut up? Perhaps make valid technical arguments instead.
Same.Not really but I’d rather rely on an intrinsic property rather than the additives. But maybe that’s just me.
I agree that if your sole criteria for choosing a motor oil is a small fuel economy increase, then this is for you.No. He stated that the 0W-12 had a new "top secret" additive pack, when the 5W-30 had a gen 2 Dexos 1 compliant add pack. But you seem to be missing his point.
Clearly, a "thin" motor oil can be made to significantly outperform an oil that is accepted to meet a well established and respected specification. So many times we see comments made as an absolute, that these thinner motor oils just won't protect an engine, and will lead to early engine failure. But in truth, at least based upon this example he shares, nothing could be further from the truth.
