Trend of making "pole barns" into single family homes
Plenty of Slab on Grade homes in this area. The difference is they are built on frost footings, and they work just fine.
Yes there is an expense to excavating the footings. However, it is still cheaper than a full basement. You only have to excavate to frost depth required by code, and only where the footings go. You do not need to excavate the rest out. There are reasons to do so besides cost - usually shallow groundwater.
They don’t work where it freezes. Period.
To have a stable foundation, you have to go below the frost line - which is five feet in Vermont.
That means you might as well have a basement.
If you put a slab on the ground - the frost will heave it up and down every winter. A house built on that wouldn’t survive.
You can do it for a barn, if the barn is actually supported by poles that go down five feet to the piers. Then the floor heaves and moves, and cracks, but the barn walls float above and stay steady and square.
My trilevels lowest floor is all a slab and we have no issues.
Imagine the property tax savings if the assessor doesn't figure out it's a residence.
That’s how lots of them started out around here - contractor builds the “barn” and then the tax base is established …
Folks would build minimum inside and move in - continue working it.
Tax man is pretty much on to them.
One couple built a huge one - later closed in more of the inside as a “party area” - from the HVAC work that unexpectedly became taxable living space … 🧐
They built a new house and are turning it back into a barn …
  • Wow
Reactions: GON
Hmm... if it wasn't mother-in-law bait, one could consider parking a tiny single wide out front as camouflage. I think I'd rather risk the taxes.
I’m sure they hooked up with a real estate lawyer - the new house is large/nice and both structures are on 15 acres inside the city limits. With a Ford Platinum pickup, Lincoln SUV, and C8 Vette parked there - plenty grownup toys - doubt they are in a bind - just got really PO’d that a seldom used area increased taxes by 40% etc …
I thought the whole idea of pole barns was to give a property tax break to farmers, ranchers, and industrial users. Putting houses inside them defeats the purpose of them and naturally residential taxes would be due I expect.
A potential issue is if the property is what's called mixed-use (residence w/business) so the homeowners can't get residential financing.
Makes me wonder how IL's residential building code is. My townhouse is built on a slab but I don't know how deep it goes - I just know that some complexes' foundations are cracking (built ~15 years ago.)
But then again my specific complex was hastily and cheaply built. The original owner of my townhouse, 2 owners ago, said he didn't find any insulation in the exterior walls plus you can hear your neighbor do the funky-funk if they're loud enough.
You can pour footers below the frost line, and stabilize the slab that way. But if you’re doing all that, building a basement isn’t much more…
My buddy finished this one this year. Wouldn't take much to make that porch end into an apartment. On slab, southwest PA.
