JHZR2
Staff member
What's your recommendation for a set of tools to put into a travel tool kit? The kind of thing that lets you do 90+% of any repairs that you could practically do on the side of the road?
My euro cars all came with a wrench set. its a group from 10-17mm, open end with a different size on each. They work well enough... not snap on tools by any means, but they will turn a bolt. Also with a dual head screwdriver so you have a flat and a philips.
The MB comes with pliers, the BMW kit does not.
But all these tools can be improved upon.
Im thinking:
-set of 3/8" standard sockets (metric) on a metal strap
-3/8" ratchet
-Better screwdriver with interchangable bits
-a right angle screwdriver to use the same bits for tight spots
-better pliers
-Small adjustable wrench
Any other suggestions?
Tell me about pliers... just a standard common size plier? Something bigger? Maybe a smaller or needlenose version?
Anything else? I suppose some rubber hose. Multimeter if you really want to get serious, though Ill bet the heat in a car will kill it.
THanks!
Im thinking:
-3/8" ratchet
-better pliers
THanks!
