Looking for confirmation on what fluid to use in the transfer case of my 2006 GMC Yukon XL 1500. There are two options in the owners manual: Transfer Case (All-Wheel Drive with Stabilitrak) calls for DEXRON-III and Automatic Transfer Case (Four-Wheel Drive) calls for Auto Trak II. I have the NP8 RPO code, which I think means the 246 transfer case, and the JL4 RPO code, which I think means I have Stabilitrak (but maybe it just means i have "Active Brake Control"? is there a difference?). I have buttons for 2Hi, 4Hi, 4Lo, and Auto 4WD on the left side of the instrument panel and a traction control button on the far right side.
So it really seems like this comes down to whether or not I have Stabilitrak. If I do I think I should be using DEXRON-III. This is of course no longer available, so I should instead be using the GM 88861800 manual transmission and transfer case fluid (apparently DEXRON-VI isn't backwards compatible in transfer cases). But, almost everything I read online says the 246 transfer case should use Auto Trak II. Is Stabilitrak in fact the difference here? And is there a definitive way to tell whether or not I have it, and therefore which fluid I should be using?
