I do maintenance on a 2001 Ford Windstar. The ford DVD ROM maintenance manual doesn't list procedure for trans filter and pan drop. I did this last weekend. Man was that a mess!!!
The only procedure they have listed for changeing transmission fluid is to disconect lower line at trans, plug hole, put tube on trans line and drain fulid into bucket while engine is running.
I have always avoided this method and used more frequent pan drops.
My questions: Has anyone used ths method for the vehicle stated above? If so what size hose will I need to attach to the trans line? Can the trans be damaged by using this method? If you have done this before for a Windstar do you have tips, tricks or advice before I try it?
