So I reseated the disc, and everything went in smoothly. I finished putting everything back together this afternoon, but I have some other issues. I don't know if Singlemass flywheels, or just aftermarket parts will make noise. Note that I currently have the car on stands. I did a little test by putting it in gear while it's in the air to see if everythings right, seems to be. In neutral I can rev it as high as I want, but in gear, the speed and revs are limited, even with traction control off. The other issue is that the engine and trans shake the whole car doin it, but I know some cars don't fully turn off the traction control, even if you hit the button. At first, there was a loud scraping and grinding sound from the trans, but after about 10-15 mins if running it, it went away. There's still a very faint scraping sound, but it's not that bad. I didn't have enough fluid for it. It takes about 2.2qt, and I put a little more than 1.5qt in. I asked Clutch Masters if there's some break in period. Do new parts make noise before being broken in? I'd think that if something wasn't aligned right, it, the trans wouldn't even fit, like the first time I tried. I read the service manual on how to install everything back, and there wasn't some super specific way on how, just torque down bolts/nuts at a specific torque spec and you're done.
