2009 Nissan Versa - broken front wiper linkage - Red Green temporary fix
Winnipeg MB CA
My friend texted saying that the front wipers on his 2009 Nissan Versa were out of sync. I invited him over, fully expecting that the soft metal on the base of one of the wiper arms had deteriorated and was no longer firmly affixed to the splined shaft on the linkage.
I expected to tighten down the arm, or remove it and put in a bit of aluminum foil to take up the slack.
But no - the driver's-side arm was firmly (very firmly - it was a beast to remove) still attached to the linkage, but was not moving well, much slower than the passenger-side wiper, so the two wipers were clashing.
The wiper blade had frozen to the windshield, and when my friend went to use the wipers, it seems something broke in the linkage.
There are a couple of options on Rock Auto for replacement linkage assemblies, but when the weather improves we'll remove the cowl first and see if we can get away with a repair rather than a full replacement.
But in the meantime, it's full-on wiper season, with mild temperatures, and lots of slush and puddles on the streets.
So, my work-around, until we can do a proper repair, was to transplant the larger driver's-side wiper onto the passenger-side splined shaft, and readjust the parked position so as to maximize the sweep of the one-only wiper.
We're pretty happy with the results - the coverage is almost as good as it was with two wipers. If I'd used duct tape, I'm sure Red Green would have welcomed me into the Possum Lodge.
That’s right out of the Versa survival handbook!! That is a proper repair. Looks very European.
Agreed, it's got a bit of a Citroen or Peugeot vibe to it now. (Coincidentally enough, I read somewhere that Renault (which is in partnership with, or owns, Nissan, depending on your source) developed that Versa and Nissan developed the Sentra, which is why Nissan has two such similar cars in its lineup.)
There was a Brit sports car of the past (an MG I think) that had three front wipers. That was weird. And I think the Camry wagon had two rear wipers, which also looked weird.
The owner wanted to have both wipers working, so I replaced the linkage this afternoon. Used the Dorman from RA. Installation was not hard.
Funny thing - the wipers started out in reverse - that is, from their parked position low on the windshield, they tried to go downward onto the cowl.
I tried repositioning them a few times, but finally realized that something must be messed up, hopefully with my installation rather than the new linkage.
I took everything apart again, and realized that when I transplanted the old wiper motor over to the new linkage, the drive arm could go on one of two ways.
I shifted that to the other possible position, and the wipers work well now.
New (top)
Original (below)
Wrong
Right
Live and learn!
