Quote:
As far as cost goes, the T-IV can be purchased online from a Toyota dealer for less than four bucks a quart.
Please tell me where!
Quote:
"Damage caused by fluids other than T-IV ATF is not covered by your new vehicle warranty."
That's very specific. Whether Amsoil is superior fluid (or not) is not the point. The point is that none of us know if we are going to be the unlucky ones with transmission problems. The problem for transmission failure may NOT be the fault of the Amsoil or T-IV (or whatever). BUT what if Toyota or GM or Volvo says the fluid caused the problem AND you cannot prove you have used nothing but T-IV? Now you are left to deal with Amsoil's warranty. What if Amsoil's chemists prove theif fluid did not cause the failure? They are not going to pay the warranty bill and rightfully not. Now, your dealing with the auto maker who have said they won't pay for your transmission because you didn't stick with T-IV, forcing you to either take them to arbitration or to Court or pay for the repair/replacement trans. yourself.
Yeah, it almost certainly won't happen because Amsoil makes a great ATF and because today's transmissions are very reliable...and because 'How can "they" tell I strayed away from T-IV?'
But...what if it DOES happen...to you?
Quote:
Unless you use Type-F, mineral dex/merc, or some other non-HMF'd cheapo ATF, you won't have a 'fluid caused' failure. Most transmission failures are now caused by sloppy programming, cheap mechanical parts sourced from the lowest bidder, and electronical failures.
Quote:
Amsoil has a perfect record of not voiding any warranty (even with extended fluid changes) in 35 years for any of their recommended product applications. Plus they offer their own warranty. Don't worry about it.
