Here is a an analysis that covers that covers 9 months including an entire Alberta winter - Oct 4/04 to June 1/05.
Vehicle: 1984 Toyota Cressida
Engine: 5MGE 168 cu inch, in line 6 cyl,
double overhead cam
Oil: GC 0w-30 batch M0233868784A1 1512
Makeup oil: Nil
Miles on oil: 6,000
Miles on Car: 57,287
UOA by: Metro Tech - Calgary
Oil Filter: Motomaster Premium FL8A
Driving: 100% city driving, engine did not
exceed 3,000 rpm's for the entire oci
Tin 1
Lead 135(highlighted on the report)
copper 11
Aluminum 2
Silicon 22
Iron 20
Chromium 0.8
Silver 0
Zinc 1050
Magnesium 147
Nickel 0
Barium 0
Sodium 9
Calcium 2000+
Vanadium 0
Phosphorus 903
Molybdenum 0
Boron 17
Manganese 9
Vis @ 100C 12.58
Water 0
Solids Glycol No
Fuel Dilution: No
Metro Tech Comments: " VF6807 - dust/dirt. Cylinders; pistons; rings wear. **Suspect lead based additive**
I did use a can or two of fuel system cleaner because I have a continual problem of additive buildup on the intake valves making the car almost impossible to start. This car sees only severe service use, I am retired and my daily trips are to the coffee shop, grocery shopping etc.
Any comments if I can get away with one oil change per year? Thanks.
double overhead cam
Makeup oil: Nil
Miles on oil: 6,000
Tin 1
copper 11
Aluminum 2
Silicon 22
Iron 20
Chromium 0.8
Silver 0
Zinc 1050
Magnesium 147
Nickel 0
Barium 0
Sodium 9
Calcium 2000+
Vanadium 0
Phosphorus 903
Molybdenum 0
Boron 17
Manganese 9
Vis @ 100C 12.58
Water 0
Solids Glycol No
Fuel Dilution: No
