- Messages
- 127
- Location
- Birmingham, Alabama
Code
2013 Toyota Tacoma 4x2 2.7L 4cyl 70,027 miles on vehicle NAPA Syn 0w20 Fram Extra Guard ([censored]) Blackstone Comments: The NAPA oil and Fram filter held up quite well. The viscosity was right in spec for 0w20 oil and it obviously did a good job of keeping internal parts well lubricated. Wear levels match up nicely with the averages, which for this type of Toyota engine are based on ~6,200 miles of oil use. No contamination from fuel or coolant was found, and the low insolubles show that the oil filter kept excessive solids out of the flow. The TBN was 3.7, showing plenty of active additives left. In our experience, low cost oils/ filter get the job done just like the more expensive brands. Mi on oil 5161 MI on Unit 70027 Sample Date 5/9/19 Make Up Oil 0qts Aluminum 2 Chromium 0 Iron 10 Copper 1 Lead 0 Tin 0 Molybdenum 27 Nickel 0 Manganese 0 Silver 0 Titanium 0 Potassium 2 Boron 6 Silicon 10 Sodium 265 Calcium 1810 Magnesium 84 Phosphorus 631 Zinc 712 Barium 0 SUS Vis 52.7 @210F cSt Vis 8.08 @100C Flash F 400 Fuel % <0.5 Antifreeze% 0.0 Water% 0.0 Insolubles% 0.2 TBN 3.7
