Thanks for the advice, I'll pass it on to the owner of the avalon... aparently he is satisfied with this uoa. The fact the he didn't change the filter was not intentional, he intends on changing it he just forgot or something...quote:
Originally posted by slider:
Usually I complain that folks here are changing oil far too often, but I think you should cut it back a little even though your wear is low. At least change the filter halfway through to give the TBN a boost. I would suspect you very well might have high temperature deposits developing under your valve cover.
These engines are not very kind to their oil - I run 12K intervals in my Sienna (same engine) with Redline and the oil is getting marginal at that point IMO.
Ahh.. you make a good point.. this has to be the s3k then.. not the 2k.. my appologies.quote:
Originally posted by Bill:
bythabay,
The UOA shows little wear but I see that this UOA is for Amsoil S2K which is 0W-30 but the on the analysis 5W-30 is listed,
which one is right?
This oil thickened some, 69.4 SUS is a cSt of 12.8, just into the 40 weight territory.
The TBN was very low, I would cut back to 12,000 mile OCI.
Thanks for the advice, I try to get them adjusted.quote:
Originally posted by bythabay:
>Anyways, I've got a sienna van with 270k sitting in >the garage right now...
Have you had any valve adjustments during that time?
Those who have worked on these engines have said that the valve seat tends to wear faster than the valve train. IOW, the valve tightens, rather than becoming noisy, which can potentially lead to a burned valve situation.
Doing valve adjustments on the back head are a real *****!
Mine has only 148K, still runs perfectly, and is spotless under the vlave cover.
code:
Al 3 2
Cr 1 1
Fe 12 9
Cu 4 7
Pb 0 1
Sn 0 0
Mo 1 2
Ni 0 0
Mn 0 0
Ti 0 0
K 2 0
B 3 13
Si 18 17
Na 11 8
Ca 2852 1108
Mg 106 598
P 933 842
Zn 1099 944
Ba 0 0
Viscosity 69.4 ?
Flashpoint 360 ?
Fuel
Insolubles 0.4% ?
TBN 0.1 ?
