From alloy artifacts website:
S-52 1/2-Drive Dual-Pawl Ratchet
In 1951 W.J. Johnson filed a patent for an improved fine-tooth ratchet design, and the resulting model S-52 (and related) ratchets became highly successful products for J.H. Williams. In this next figure we'll look at a very early example of the S-52 ratchet and discuss the patent behind it.
Fig. 322. Williams S-52 1/2-Drive Dual-Pawl Fine-Tooth Ratchet, with Insets for Side View and Reverse, ca. 1951-1956.
Fig. 322 shows an early example of the Williams S-52 1/2-drive ratchet, with "S-52 Superratchet" and "Pat. Pend." forged into the handle, and with "J.H. Williams & Co. U.S.A." forged into the reverse.
The overall length is 11.2 inches, and the finish is polished chrome.
The patent pending notice corresponds to patent #2,772,763, filed by W.J. Johnson in 1951 and issued in 1956. The patent describes a ratchet mechanism with a dual-pawl progressive advance design, closely based on an earlier patent #2,395,681 by W.H. Odlum et al of Duro Metal Products.
The key to the patent is the use of dual pawls with an odd number of gear teeth, so that the pawls are always a half step out of synchronization. This allows the ratchet to get another "bite" with only half the angular displacement, effectively doubling the gear pitch.
