I have a Vondior air gauge that I have had for a couple of years now. I need to check to see if it is accurate. I wasted a video by Project Farm on Youtube where he does test reviews of various products. In this video he tested many different air gauges and the Vondior analog gauge was by far the most inaccurate of the bunch.I bought two dial type gauges made by Vondior. They came with a certificate of calibration. I tested them and both read consistently the same. Then I compared them to an old dial type gauge that was probably 20 years old. That gauge was off by 3 lbs compared to the Vondior gauges. I used to run my tires +1 lb. over the recommended pressure so I was really under inflated by 2 lbs per tire for many years.
Then I compared the new Vondior gauges with the digital readout of each tire on the dashboard display of my Jaguar. The Jaguar reads 1 lb. less than the dial gauges. Close enough for me. I stopped using a pencil type gauge decades ago but when I checked an old one that I had lying around it too was about 3 lbs low compared to the new calibrated gauges.
https://www.amazon.com/dp/B072Z4SBN9/ref=dp_iou_view_item?ie=UTF8&psc=1
Do you recall what brand of gauge won? Just curious. I don't really care for watching influencer/creator YouTube vids, else is looking it up and watch it myself. Lol. Thanks!I have a Vondior air gauge that I have had for a couple of years now. I need to check to see if it is accurate. I wasted a video by Project Farm on Youtube where he does test reviews of various products. In this video he tested many different air gauges and the Vondior analog gauge was by far the most inaccurate of the bunch.
I have a pencil type gauge where the reading could be adjusted (calibrated). It had a tiny hole in the side of the body where you stick straightened paper clip (or similar) into the hole and screw the scale in or out to calibrate. I think it was Tru-Flate gauge. Problem is, what do you calibrate it to?
Those of us who have load range D trailer tires running 65 psi need that range, but I use separate gauges for cars and trailers.I spent a lot of hours as an instrument apprentice using dead weight testers. Wish I had access to one now.
The stupid thing about dial gauges is that they sacrifice accuracy and readability by being an inappropriate range. They are almost all 0-100 psi when 0-60 psi would cover 99 percent of requirements and be potentially near twice as accurate into the bargain. These things are marketed as if a high range was a good thing when in fact for 99 percent of us it's the exact opposite.
