Thoughts on partial oil change?
Not worth the effort. I have a few empty quart bottles around and would just drop the quart from the 5 quart jug into one of them. Eventually it will get used.
A few previous threads on this particular topic that may be helpful. There are a few more:
I assume you have a naturally aspirated engine; if this is not the case (i.e., you have a turbo) everything below may be irrelevant.
Buy individual quarts instead of a jug during a parts store sale/rebate offer; they don't care if you take a 5 qt jug or individual qts. Then you only have a single qt bottle on the shelf.
Also, for the oil-only change in the middle, don't change anything at 2k. Use a premium filter and do an oil-only change at 4k. Change the filter every 8k. Unless, of course, you have a confirmed dirty engine that could benefit from frequent OCs (like my Cadillac 3.6).
I have a fumoto drain valve on my car that + my set of ramps I can already do a full oil change + filter in less than 15 min. My car takes exactly 4 quarts. I buy 5 quarts because they are much cheaper. But hate having them take up space in my hot and humid garage.
I know there is really no added benefit to doing this, but it cant make things worse right? I do 4k change intervals and was thinking drain a quart and 2k mark and add the quart i have left over
I extract the oil every 2500-3000 miles on the wife’s Rogue and change the filter between 5&6k. I could see you doing similar. That’s just me being proactive on maintenance for the vct engine.
I store odds and ends of oil outside in a box in my yard. (I do have a big lot).
Just keep the extra oil in your basement or closet. That's all.
Here's a partial oil change. Trying to use up some of the stash. Actual mileage around 3000 on Kirkland Signature FS 0W20, will run the Nissan JP MAHLE filter another 3000.
This isn't the first thread with someone who doesn't want to store a quart or partial quart of oil. I think this is the sort of person who should live in an efficiency apartment in Japan. One leeetle rice cooker, one leeetle frying pan, one leeetle bowl..............
Im all for it. And I really like the M1 hybrid oil.
Need more details though. What is the capacity of the vehicle? I think you have enough oil for a full change.
Full oil change with filter somewhere in the 5 Qts range. I have done this several times now and 4 Liters seems to be all I can extract out and I yank that pump to my guts fall out conversion is 4.227 Qts. I pour in 4.25 and pull the stick and it's living in the happy zone now come next oil change I will drop the filter and it will probably take 4.89 Qts. Mobil 0W-20 Hybrid is nothing more than a tweaked AFE formula if I had to guess but it is a good oil from what I hear this is my 1st time running it.
All good. So really it’s not what one would say a partial drain and fill, like 1 qt. For you, it’s the limitation of how much you can extract out. No big deal with the residual.
I also have a fumoto valve on my two cars. For me this is very helpful. However since I'm 87 years and sometimes a bit slow the oil change takes me a bit longer than the time you can do it in.
