Not worth the effort. I have a few empty quart bottles around and would just drop the quart from the 5 quart jug into one of them. Eventually it will get used.
Exactly! Must be real slow here on BITOG lately with these type of threadsJust use the quart up on the next oci, then you'll have two left over, then three and then enough for a complete oci.
it cant make things worse
Glad I searched and didn’t start a new post.You've summed it up well already.
I extract the oil every 2500-3000 miles on the wife’s Rogue and change the filter between 5&6k. I could see you doing similar. That’s just me being proactive on maintenance for the vct engine.I have a fumoto drain valve on my car that + my set of ramps I can already do a full oil change + filter in less than 15 min. My car takes exactly 4 quarts. I buy 5 quarts because they are much cheaper. But hate having them take up space in my hot and humid garage.
I know there is really no added benefit to doing this, but it cant make things worse right? I do 4k change intervals and was thinking drain a quart and 2k mark and add the quart i have left over
What are you saying a few quarts short an oil change lol jkThink the OP left the building long ago …
Why? 7500 miles was the commonly recommended OCI 25 years ago.I extract the oil every 2500-3000 miles on the wife’s Rogue and change the filter between 5&6k. I could see you doing similar. That’s just me being proactive on maintenance for the vct engine.
This topic was relevant to me.Think the OP left the building long ago …
Just keep the extra oil in your basement or closet. That's all.I know there is really no added benefit to doing this, but it cant make things worse right? I do 4k change intervals and was thinking drain a quart and 2k mark and add the quart i have left over
