Not worth the effort. I have a few empty quart bottles around and would just drop the quart from the 5 quart jug into one of them. Eventually it will get used.
Exactly! Must be real slow here on BITOG lately with these type of threadsJust use the quart up on the next oci, then you'll have two left over, then three and then enough for a complete oci.
it cant make things worse
Glad I searched and didn’t start a new post.You've summed it up well already.
I extract the oil every 2500-3000 miles on the wife’s Rogue and change the filter between 5&6k. I could see you doing similar. That’s just me being proactive on maintenance for the vct engine.I have a fumoto drain valve on my car that + my set of ramps I can already do a full oil change + filter in less than 15 min. My car takes exactly 4 quarts. I buy 5 quarts because they are much cheaper. But hate having them take up space in my hot and humid garage.
I know there is really no added benefit to doing this, but it cant make things worse right? I do 4k change intervals and was thinking drain a quart and 2k mark and add the quart i have left over
What are you saying a few quarts short an oil change lol jkThink the OP left the building long ago …
Why? 7500 miles was the commonly recommended OCI 25 years ago.I extract the oil every 2500-3000 miles on the wife’s Rogue and change the filter between 5&6k. I could see you doing similar. That’s just me being proactive on maintenance for the vct engine.
This topic was relevant to me.Think the OP left the building long ago …
Just keep the extra oil in your basement or closet. That's all.I know there is really no added benefit to doing this, but it cant make things worse right? I do 4k change intervals and was thinking drain a quart and 2k mark and add the quart i have left over
Im all for it. And I really like the M1 hybrid oil.Here's a partial oil change. Trying to use up some of the stash. Actual mileage around 3000 on Kirkland Signature FS 0W20, will run the Nissan JP MAHLE filter another 3000.
View attachment 342359View attachment 342360View attachment 342361
Full oil change with filter somewhere in the 5 Qts range. I have done this several times now and 4 Liters seems to be all I can extract out and I yank that pump to my guts fall out conversion is 4.227 Qts. I pour in 4.25 and pull the stick and it's living in the happy zone now come next oil change I will drop the filter and it will probably take 4.89 Qts. Mobil 0W-20 Hybrid is nothing more than a tweaked AFE formula if I had to guess but it is a good oil from what I hear this is my 1st time running it.Im all for it. And I really like the M1 hybrid oil.
Need more details though. What is the capacity of the vehicle? I think you have enough oil for a full change.
All good. So really it’s not what one would say a partial drain and fill, like 1 qt. For you, it’s the limitation of how much you can extract out. No big deal with the residual.Full oil change with filter somewhere in the 5 Qts range. I have done this several times now and 4 Liters seems to be all I can extract out and I yank that pump to my guts fall out conversion is 4.227 Qts. I pour in 4.25 and pull the stick and it's living in the happy zone now come next oil change I will drop the filter and it will probably take 4.89 Qts. Mobil 0W-20 Hybrid is nothing more than a tweaked AFE formula if I had to guess but it is a good oil from what I hear this is my 1st time running it.
With this particular vehicle I had measured the one time I removed the drain bolt and it was very minimal the difference between a pan drain vs extraction I wont even bother stressing myself about the ounces left behind vs the possibility of screwing up a composite pan with a threaded brass insert.All good. So really it’s not what one would say a partial drain and fill, like 1 qt. For you, it’s the limitation of how much you can extract out. No big deal with the residual.
