Down side of partial oil changes?
Every oil change is a partial oil change. They all hold some fluid somewhere. It is just a matter of degree. I've left filters in for another run rather than replacing them as mentioned. For work, I maintain filters in other applications, and leaving them with some loading increases their low-micron filtration capacity. As the filter loads, you lose flow capacity so you either start with a larger filter than needed (which is a tricky subject) or use a filter with a lower micron rating, to begin with. The thicker the filter media the better they load and automotive oil filters are typically just thin paper media. They load, then lose flow, so it probably would be best to have a pressure drop manifold where you could evaluate the filter but that is too much work. Just swap them and I don't see the point of a partial oil drain for the same reason. It is too much work. If I'm under the vehicle it is all coming out.
Yeah, I'm not a fan of this technique. You're leaving contaminants in that dirty oil and just replenishing some oil - I think it would be ok to say, maybe extend an oil change this way a couple thousand miles (by siphoning out a couple quarts and replenishing it), but not actually bypassing an oil change entirely. IMO.
  • Like
Reactions: pbm
No harm. Also, no benefit.
If you’re able to extract a quart, why not extract all of it?
I should clarify this. I do not always siphon out 1 quart. If the vehicle has been drive aprox 3,000 miles, I have removed maybe 2.5 quarts and replaced it with new. If only drive 1,000 and winter is coming [don't want to change oil in the snow] I may only change a single quart to freshen the oil. I try to calculate how much needs to be changed.
When a regular oil n filter change is done, some oil is always left in the engine.
Two problems I can see. Without removing the drain plug, over time some sediment may accumulate in the bottom on the pan.
Second, if the oil is never brought up to completely fresh, the cleaning agents may never be strong enough to remove deposits from the engine.
Just wondering what people think. Later this year I'll probably give it a full change and see what Blackstone finds.
What a bout a continuous use diesel power plant? Is some oil change done with the engine operating?
Seems like you answered your own questions
If you can’t or do not want to do a proper oil and filter change yourself for any reason then have a friend, family member, or shop do it, and do it correctly.
There’s one right way and many wrong ways to do anything. A partial oil change is not the right way, imho it’s just a waste of new oil.
Z
Why not just do oil change while it's still nice and warm out and before it gets cold? You said you didn't drive much, so one warm day in fall season would do it in case you wanna do it yourself and not to take it to a shop that does oil changes. Just keep adding oil till next fall when you do another oil change or so, as long as you stick with your OCI.
If anyone agrees with this procedure, I humbly suggest you don't listen to them.
Get a MityVac, have someone help you or pay for an annual oil change.
If you lived near me, I would be more than happy to lend a hand. Good luck.
I don't like getting under my car and I don't drive as much as I used to so I have simply siphoned a quart out of the sump and added enough to bring it up to full mark for the last year or so. Engine uses a quart per 4,000 miles. Filter is an oversized Fram Ultra so I'm not worried about that. Question is, if this were to continue indefinitely, is there a downside to not ever totally draining the oil?
Yes plenty of reasons not to do it.
A few of the big ones are....
Expunging "Ghost Riders" that accumulate under 10 microns keep accumulating unchecked by the even the best full flow filters.
Reduced oxidative protection.
A tiny amount of oxidated oil - contaminates the new oil very quickly. It takes less than 5 percent oxidized oil mixed with new oil to reduce the oxidation stability of the new oil by more than 90 percent.
Reduced Devrnishing - SVOC results in highly reduced impurity holding capability.
I've known a few guys who just added oil and swapped a filter. Seemed to get away with it too.
Friend of mine had an old Chevy Truck ( 1972) and the dipstick tube was broke off... so he would drive it until the oil pressure light would go red if he was rounding corners....and throw 3 quarts in it... and he sort of kept track of it like that and about the 3rd time he had to add 3 quarts of oil he would throw another filter on it.. he drove it like that for a long time.. Not the preferred maintenance method but it worked for him.
I think it's a bad plan for motor oil. You're only diluting the total of ~5 total quarts, with 1 fresh quart. If you do the complex math, you're going to have a lot of really really old oil in the engine after 10s of thousands of miles.
This might work in a transmission that has a 75,000 mile change interval, if you do this method every 10k miles or similar. But in an engine just replacing 20% of the oil every 4000 miles is not going to be sufficient.
Plus how are you changing the filter? Unwise to leave a filter on for 10s of thousands of miles or long time intervals.
One strategy might be a Mityvac to suction out all the oil, and change the filter every other OCI.
Now there's been times right I had two or three quarts that I found laying around. Especially right when my mom was dealing with chemotherapy and I was over there using her driveway cuz it's much smoother. I had thought the oil analysis kit and it had refrigeration tubing included and I just siphoned out that three or four ounces into that little clear bottle and then dumped it over into an old 5 quart jug. I bet you I had to screw that bottle back onto the softer 40 or 50 times. I really wanted to get underneath there but it's stressed out as my mother had been I just figured I only had another three or four thousand miles to go before my maintenance speeder turn down at 20%. While siphoning I noticed I got a lot of what seem like a water like substance so it was probably gasoline. I know it wasn't the optimal way to exchange fluids, but it's sure better than not changing any of it at all. Of course we already got ours up to operating temperature so I never worried about the oil oxidizing or coagulating. It's better to change some than none but don't make it a constant habit as eventually some of the things down in the sump just need to be removed. It sounds like you might be a candidate for the high performance lubricants engine cleaner 30. Maybe sorry for that around 2 quarts and 1/4 of the engine cleaner and one quart of whatever oil you wanted to use and run it or maybe two or three thousand miles and then have it properly drained from the pan.
You'd be better off buying a cheap oil extractor from Harbor Freight, about 100 bucks. They're pretty decent at getting out nearly as much oil as a normal drain would, and replace nearly all the capacity. Not replacing the filter leaves maybe half a quart give or take depending on filter size. Should change the filter every other or every third change depending on frequency though.
You'd be better off buying a cheap oil extractor from Harbor Freight, about 100 bucks. They're pretty decent at getting out nearly as much oil as a normal drain would, ....
Or you can buy a 12-v electric pump that will do the same thing for 20-something dollars. Besides being cheaper, it has the advantage of requiring less storage space. I've used mine successfully, twice so far, and soon will again.
Whether "getting out nearly as much oil as a normal drain would" is feasible by sucking it out the dipstick tube is highly vehicle-dependent; it works on some, not on others.
Why would you do partial oil changes. Reminds me of the days when I was younger & worked at a no name gas station where we would put that green oil that we had in drums & put in glass bottles to sell to people who were driving smoking clunkers.
I am NOWHERE near as anal as most of the people on this site and even that is not something I could condone . Change it , or have it changed once a year at least .
I understand that you do not like getting under your vehicle. If you intend keeping your vehicle, I would supply your own oil and filter and have some one change the oil and filter once a year.
I am not a fan of partial oil changes and would never leave an old oil filter on with a partial oil change.
If the engine is at operating temp, then most of the oil will drain out taking some heavy sludge with it thus reducing wear in your engine. Changing all of the oil and filter is money well spent rather than spending money on oil tests.
