guys, i'm not knocking vibes in general (it's mostly a toyota matrix, with a few gm goodies messing things up
$5,000 for a good vibe, yes. Not this one. he over paid for THIS PARTICULAR vibe.
he knew that was the model he wanted, and had just inherited a little money, and bought the first one he saw, with out having it checked out.
@ all.
not even carfax.
(spring/ Summer 2010, @ that time a 7 yr old car, with 120k miles)
1)it's an obvious front end total, w/a quick, "that'll do" repair job.
2)none of the seams are consistent up front, fenders are not quite "home"( you can push it -the fender not the car- down a bit where it is supposed to meet up with the A pillar.
3)NONE of the splash guards/inner fender plastic liners are present.
4)blower ONLY works on high(we replaced the resistor, didn't fix squat),
5)has the blend door flap (broken plastic gear in blend door motor constantly ticking back & forth [GM part, the Toyota's use a totally different system])
6)passenger door internals are mangled up to where the window motor isn't aligned properly(DON'T DARE ROLL IT DOWN!!, putting it back up is a 2 person job, one to operate the switch, the other to keep it in channel manually)
7)struts all need replaced
8)drivers door grinds against the fender whenever you open it.
8a)the door stays are broken so the doors swing ALL the way open
9)console is cracked,
10)radio was starting to fail until i got him an aftermarket unit for Christmas
that's just off the top of my head......
still think he got a good deal?
