Those with 150,000 miles or more, check in
06 Altima 2.5 4 cyl- 175,000 mi. OCI 3,500 w/ Mobil One 5w/30, and Mobil One filter. I keep it slightly overfilled-maybe 1/8 to 1/4 qt. I'd rather (after a long trip) have it run down to factory level, after starting out overfill, than have it start out at factory recommended level and end up low. Also it's a timing CHAIN engine-better a little extra oil to keep the chain bathed? Also 89 Camry 2 liter 4 cyl- 154,000 mi-Castrol GTX for years, just switched to Castrol semi-syn. Also Mobil One filters, also slightly overfilled (although this one's a belt), no oil burn on the Camry, only a wee bit on the Altima. BTW-transmission "flushes" on a regular basis. The body and "chassis" will be long gone and the engines and transmissions will still be strong!
How much oil does it burn? Generally not recommended to overfill, but that low amount is probably ok.
What do you use for the CVT and how often? Do you change the filters?
Those 2.5L engines are tough!
Several months ago, I was gifted an '05 Altima 2.5L with only 39k miles; needs nothing and garage kept. New tires, new CPR on the rear and just new pads and rotors on the front. I'm not afraid of the CVT, I once owned an '07 Maxima and it was great. The Altima has the 4spd and the only thing I noticed is a very firm shift from P to D and also from 1 to 2. I serviced the transmission and looks like it will need a 1-2 shift solenoid; that's all! The A/C is ice cold too! Nissan (y)
1997 Chevy lumina 180k-most supertech changed every 3,000. SOLD
2001 impala 3.4 184k miles-,mostly super tech changed every 3-4k, -sold
2004 Pontiac vibe, 199,984 miles-valvoline, super tech, and Mobil 1-traxed in for the Avalon
2008 Toyota Avalon with 184,000 miles. Oil changed every 3,500 miles since bought with 60,000 miles. Still on the road.
2012 Nissan versa s hatchback 1.8L w/4 speed auto-172,000 miles. Oil changed every 3,500 miles since I married my wife with various brands. Unknown maintenance (most likely poor) first 80k miles. -Still on the road.
I've used Mobil 1, Valvoline, Napa, super tech, and quaker state.
I've found Quaker State to perform well for the cost. Its what they all get now.
42 43 44
I think you have to go for 500k now!
I'm thinking somebody's going to have to help me with wrenching on it. I have a love-hate relationship with that car you would almost have to ride with me and appreciate the sounds of taking a vehicle that has great performance name brand parts added on to it but for a model of vehicle that doesn't have a lot of aftermarket support. Some days I think about just turning it into a e15 or E85 vehicle but the aftermarket support on the 9th gen 2.4 is just not that whippy. I don't want to have to start trying to shop for parts on temu 😅
2016 5.3 Tahoe 202K miles
Out Mobil 1 Extended Performance 0w20
In AC Delco 0w20
AC Delco Filter
Will go back to Mobil 1 Extended Performance next change. Was at the Stealership for a issue so let them change the oil since it was already there.
Updated: 2017.5 Jeep Compass Trailhawk. 245,000 + miles. This thing just keep going. 5000-8000 mile oil changes. Burns no oil.
0w-20 Pennzoil Platinum or Quaker State full Synthetic. Suspension and Drivers seat are starting to feel/show the mileage. Will keep it going as long as I can. LOL
2008 FJ Cruiser
Bought with 4 miles, July 2008
Used Mobil 1 5w30, Denso or Mobil 1 filter
Switched to Valvoline Restore and Protect at 141k
Now has 151.2k
Uses zero oil
Only an alternator replaced, no internal work
Oil change interval was 3k or less until about 120k
Oil change interval changed to 5k or less
