At my job every other weekend it's my duty to check all the vehicles (fuel, oil, lights etc). Around 30 with the shuttles and other cars/vans/trucks and I've been doing it for more than a year. I'm one of those nuts that could tell you which one will be low and by how much without looking.. I consider it a talent.
To the point.. We have a couple new Toyota Sienna not quite six months old. One's at 6k the other a 9.5k. Judging by oil colors and no stickers in the window has to be original fills the way it looks. The oil is black on the 9.5k and it's Toyota that isn't normal.. don't care if you want to argue that color doesn't matter. Next victim a Prius at 107k the sticker says it needs to be changed at 100k... they're supposed to do 5k changes so that would make 12k and it's a half quart low (not normal). The last one I'll mention (there was alot more) is a E150 with 86k. The sticker on the windows says change at 70k... almost 21k on this oil change if that's right. Ought to see the oil on that one you don't have to you can smell it as soon as you pull on the dipstick. All they run is dino. I noted it again but probably like all the other times it will be ignored.
Last but not least the ones that had no oil on the dipstick. E350 shuttle with the 6.8L absolutely nothing on the dipstick. Has to put 2.5 qts to get the the bottom hole on the dipstick.. that would make around 4qts low. They only hold 6qts. Had to put 2.5 gallons in a 7.3L powerstroke about month ago.
Must say even with the abuse the vehicles get here I'm amazed how they keep running. Some with well over 100k. I know this place isn't alone in not taking care of it's fleet. I know this has been said a few times but with the way some of us take care of our vehicles the engines alone should last a millon + miles.
