Except that's the _____'s job.
No.... Not entirely.... Sometimes yes...
Only in limited certain circumstances.
My uncles used to own a logging company and there were foresters involved when the logging would take place. Historically the forests were much " thinner: because when there was a forest fire the only thing that put out the forest fires in when what ever caused it to burn out.There is a thing called thinning and selective cutting. Thin out the forests so they don’t get so choked with trees. Diseased trees go too. That will help with the undergrowth.
Why is there a mass exodus from California? That's a real crisis.I am not sure why anyone would belittle this crises.
As I read through most of this thread, it boiled down to a lot of what I assumed I would read and from the mostly the usual cast of suspects.
Basic things to consider here are that there have been cold weather capacity problems in the ERCOT system at three points in the not so recent past - December of 1989, February of 2011, and this recent event. Reports full of recommendations came out from the 1989 and 2011 events, and unsurprisingly, the recommendations were pretty much the same, and likely will be same as what comes out of this event.
Key differences to note are that in 1989, the market had not yet been deregulated. Since then, it has, making the cost of generation the only real thing matters in the market - not reliability, not resiliency to extremes, etc... In a market like that, justifying making improvements for these quote "rare" events (now three times in the last 31 years with varying results) is exceedingly tough. If you are a wind producer, and the cold weather add ons we use in the North that allow wind generation down into the -20 degree F range add to that cost to produce, would you willingly spend the money on it if you are required to? If you are a natural gas generator or a nuclear generator, does spending the money for these three events make sense? Probably not to the producer.
And yes, wind is a larger player in this event as opposed to the last two events. However, the same issues that plagued thermal producers in those two events, reared their heads again. Is the need for more thermal producers like gas facilities greater with wind generation? Undoubtedly yes. Does it appear they learned from past failures? Not particularly...
While the system did not fail to the extent it did this time around, having three events of this nature is just over 30 years doesn't point to it being a one in a million type scenario. I look at what we've already had to modify in my profession - storm water. The storms I use in the design side are 20+% larger than what they were when I started my career. That comes out of the statistics - whats already happened in the past years. Call it what you want, debate the sources of changes all you want, but there are changes in the trends of weather. When it comes to the infrastructure that society depends on (and honestly society generally doesn't think about until bad stuff happens like this) one may ask themselves if this is really a one time event or something that is going to keep happening. 3 times in 31 years should be a hint...
I would point out in a cold snap a few years ago, the wind energy predictions overestimated the amount of wind energy that would be available as they did not completely understand the cutoff point of the cold weather gear wind power in this area can handle. For this area, that was around -22 F as the temp that wind just went off line to protect the infrastructure. That has since been built into the forecasting and modeling of predicted output. Even cold weather areas get some of this wrong from time to time. Would be interesting if ERCOT had this in their projections (at the correct temps their non-cold weather equipped gear runs in) correctly as well...
It amazes me how hysterical people are about a few days of intermittent power interruption in parts of Texas, but I hear nothing but silence about California's repetitive blackouts, year in and year out. Why are people, many not in Texas and some not in the USA, in full blown PANIC mode?
Agreed; not entirely. No one said entirely.No.... Not entirely.... Sometimes yes...
I will say you guys need to study the fire triangle and see which of the 3 you can interruptAre you suggesting 2 wrongs make a right?
Saw that … mayors across all states have to be onboard for things to fly ~ for example STP nuclear plant feeds the major cities below Dallas …There was an amazing interview on Fox News Sunday AM. The reporter was questioning Michael Burgess, House Energy and Commence Committee. The reporter was "Why didn't Texas have back up plans for cold weather?" Mr. Burgess replied In 2011, then TX Gov. Rick Perry tried to do exactly that. He attempted to approve several energy plants FOR REDUNDANCY after a hard cold spell, but the inner city mayors and environmentalists railed against it and it was shot down. Go figure.
Sorry for the somewhat OT, but we are grappling with the idiocy that is the energy illiterate citiot here in Ontario. We simultaneously have the same group of people celebrating the impending loss of Pickering nuclear, which provides the majority of the power for Toronto, while rallying to eliminate gas generation. Gas is slated to go up dramatically when Pickering closes (by ~3,100MW) but these people refuse to see that the two prongs of this forked ideology are at odds with each other. They need to choose a goal but trying to have that conversation with them? Impossible.Saw that … mayors across all states have to be onboard for things to fly ~ for example STP nuclear plant feeds the major cities below Dallas …
Oh Toronto weather! … we spent 5 hours circling deicing so when the blizzard cleared the planes went airborne 1-2-3 ………………………… This for a 3-1/2 hour fight !Sorry for the somewhat OT, but we are grappling with the idiocy that is the energy illiterate citiot here in Ontario. We simultaneously have the same group of people celebrating the impending loss of Pickering nuclear, which provides the majority of the power for Toronto, while rallying to eliminate gas generation. Gas is slated to go up dramatically when Pickering closes (by ~3,100MW) but these people refuse to see that the two prongs of this forked ideology are at odds with each other. They need to choose a goal but trying to have that conversation with them? Impossible.
Now, only 3 of us in the front … so we had our share of deicing !
Lester B is YYZPearson? I assume so and not the island. What a crazy place.
Some of the stuff you hear from people just boggles the mind. I had one guy tell me a couple of years ago that Niagara falls produces half of Ontario's electricity. I'm not kidding. Energy illiteracy is a massive problem, particularly now that we have this electrification push.
Did not see the gens there … saw some beat up barrels at the IMAX theaterPearson? I assume so and not the island. What a crazy place.
Lester B is YYZ
"over the falls!"Did not see the gens there … saw some beat up barrels at the IMAX theater![]()
Yessir … some long walks much like FRAYep, Pearson = YYZ, it is one of the busiest airports I've ever been in, or can be.
