What are you talking about? The "source" is just ERCOT, it's a snapshot of total installed capacity for each source followed by anticipated capacity. There was no "cute meme", are you so eager to get offended that you'd intentionally misinterpret what has been presented?
The Capacity Factors are available here:
https://mis.ercot.com/public/data-products/markets/data-aggregation
Along with production data and all kinds of reports.
I do find it interesting however that you'd find attempted clarification on something that is clearly misunderstood as arrogant because it pushes-back relative to whatever narrative you've already decided to personally invest in.
You only THINK they contradict what I've stated because you have either willfully made the decision to misinterpret what has been stated or are not properly comprehending the material presented.
Do you understand the difference between capacity and capacity factor? Do you understand what nameplate capacity is? If not, it's OK, most people in the media don't either.
Let's try this again.
Wind was not the major factor in failing to meet demand BECAUSE IT WAS NOT EXPECTED TO SHOW UP IN ANY SIGNIFICANT CAPACITY. That fact in no way invalidates the data I've presented, and in fact is wholly supported by the table from ERCOT, which shows that while INSTALLED CAPACITY for wind, within ERCOT, is about 28,000MW, they only expected 7,000MW to be available. That's a far cry from the amount of gas capacity that became unavailable.
Do you want to try and talk through where the figures I've presented APPEAR to diverge from what the media is stating or do you want to continue to be offended? Because nothing I've said here is offensive or "mean".
The claim that wind power is only 10% of Texas's generation CAPACITY is incorrect. If you'd like a few more sources on that, heck, we can even bring in Wikipedia:
https://en.wikipedia.org/wiki/Wind_power_in_Texas
Which is consistent with the ERCOT data already posted.
So, let's go back to the ERCOT table:
For the period in question, total AVAILABLE capacity, note the emphasis, was expected to be ~78,000MW. Of that 78,000MW, 7,000MW was supposed to be wind, or roughly 9%. Do you see where the 10% figure is coming from now? So of 28,000MW of wind capacity, only 25% of it was anticipated being available. Actual capacity was half that, only 10% of installed capacity showed up on average.
On the other hand, 51,000MW of gas capacity was expected to show up, making up 65% of anticipated output, but only 32,000MW (62% of capacity) actually did, roughly a 20,000MW deficit, resulting in the rolling blackouts because available capacity didn't meet demand.
Does the table make more sense now?
So while wind is 28% of total installed capacity, the grid operators rarely, if ever, count on full nameplate capacity being available. They look at weather conditions and wind patterns and fudge a figure that should be close. In the case for the 15th, that figure was 25% of installed capacity or 7,000MW, roughly 10% of anticipated capacity, which it failed to meet by 50% on average, but since that's only a 3,500MW deficit compared to the 20,000MW deficit with gas, it was not the major factor in failing to meet demand.
This does however highlight an issue I've opined about on here before, and that's the low inherent capacity VALUE of wind. As we can see, its expected contribution relative to nameplate was quite low, which shows that grid operators are not planning around wind capacity being available in any significant amount to meet periods of high demand and instead are relying on fossil sources, typically gas, instead.
