Gokhan
Originally Posted By: Gokhan
Originally Posted By: SonofJoe
Garak,
I'd hazard a guess that a 5W30 Group III OCP VII oil will contain roughly the same level of VII as a 0W40 PAO (+ a bit of ester?) oil. Generally OW40's are based around Shellvis VII. Put this together and there's probably not much of a difference in Noack between the two oils. However the 0W40 will be significantly more expensive to manufacture.
Modern Group III+ and GTL base stocks have higher VI than PAO. Therefore, a PAO base oil requires more VII than a Group III base oil.
NOACK has nothing to do with the VII. It's entirely determined by the base oil. PAO and GTL both excel in NOACK. Non-GTL Group III has higher NOACK than PAO and GTL.
Got any examples of VI's for these base stocks? I see Mobil's SpectraSyn 10 for example has a VI of 132, SpectraSyn 40 is 147, SpectraSyn 100 is 169. The mPAO products are even higher.
The numbers after SpectraSyn indicate KV100 in cSt. These are extremely thick base stocks that are not used in motor oil or used in very small quantities.
With any type of base stock, VI increases dramatically with KV100.
You should compare typical KV100 viscosities, such as 4, 6, or 8 cSt used in motor oil. Google Shell XHVI, Mobil Visom, and Shell GTL. You will see that Group III overwhelmingly beat their PAO counterparts in VI for the same KV100.
Garak,
