It would be hard to find a thicker 30 than GC. Its KV100 is 12.2 centistokes, and the limit for 30-weight oil is 12.5. If you could find a 30-weight at 12.4, it wouldn't perform much differently.
It seems like the Pennzoil and Quaker State oils are about as thin as could be found in a 40-weight. They are only about 5% above the minimum viscosity, and they must allow some margin for shearing in order to stay in grade. All ILSAC oils must pass a test for stay-in-grade shear stability.
What's ILSAC? And what's it doing in my API and Euro rated oils?
