What's the downside to using 0W-30 vs 5W-30?
Greenville S.C.
I know there are a gazillion similar threads, but after going through a bunch of them this morning, I don't see this specific question addressed directly. I understand (I think) that the basic difference is that 0W is better for cranking at lower temps found in colder locales. My specific question is
Is there any downside for me using Amsoil Signature Series 0W-30 vs. Amsoil Signature Series 5W-30 in my 2003 2.4L Camry? What exactly is the trade-off, if any?
In SC I wonder if even 5W is required. But 0W does allow a weak battery to last a pinch longer (personal experience). No idea about the question, though, sorry. But are you planning on running 10k+ OCI's or changing every 5k?
I'd be more worried about a 2.4 pulling head bolts. Make sure to flush the coolant and keep on top of that.
No.
A few threads which might be helpful in dispelling the common misunderstanding of what the winter rating means, and what it does not mean, and when:
No.
Thank you!
What temperatures will the car see?
Often a 0W-XX oil will shear down faster due to more VII used. So a 5W-XX oil can last longer, but that isn't a rule, and different engine designs shear oil faster than others.
ironically, even this shear aspect is often untrue. There are cases where the 0w-30 will outperform the 5w-30 in shear stability. This is because the higher VI base stocks are so naturally shear stable and have higher VIs such that you don't necessarily have an oil chocked full of VI just because it's a 0w-30.
Yep, and the narrower Winter grade oils can be blended cheaper, using cheaper bases.
At operating temperatures, they are both -30 weight oils. Down to -22º F (which you'll never see in SC), they're both effectively the same at cold temperatures.
Buy whichever is less $$$ or more readily available.
...and there is Mobil 1 ESP 0w30 that is thicker than most 5w30's at operating temperature, and I haven't seen any reliable reports of the ESP 0w30 shearing such that it would be considered "more than" most 5w30's.
No, there is no downside nor trade-off.
Those are mostly the same oil. However, the 5W-30 has lower Noack on paper (6.7 vs 8.8 for 0W-30). In this case I would choose the lower Noack.
From the top the oil properties are:
KV at 100°C
KV at 40°C
Viscosity index
CCS
Flash point
Fire point
Pour point
Noack
HTHS at 150°C
TBN
KV at 100°C
KV at 40°C
Viscosity index
CCS
Flash point
Fire point
Pour point
Noack
HTHS at 150°C
TBN
Yes, I noticed the Noack difference. So a little background: I'm still a newbie on here and still learning. I bought the 0W-30 a while back under the impression that if 5W-30 was good, 0W-30 is even better, with the real difference being better cranking in colder/lower temps with the 0W. While that wasn't wrong, I realize now, thanks to time spent here, there's more to it. While I am perfectly fine using 0W-30, 5W-30 may be more "optimal" (that's what Amsoil said), and that's probably what I'll go back with. I really appreciate the opinions and advice from all of you here, all of whom are more knowledgeable than me.
Below -30 or so. Above that there is no guarantee.
In this case, when an oil line such as Amsoil’s Signature Series isn’t cheapened for the narrower grades, I’d go with the 5w-30 for the improved volatility, but either are superb oils and it’s not like the 0w-30 is lacking anything here.
Bench racing them on the product specs sheet isn’t necessary applicable to most real world scenarios, but to be honest I recently bought some of their 5w-30 for next time musing over the Noack numbers too. 😅
More for curiosity sake than anything. ;)
Ironically, per the info @Japanese posted, it appears the 5w-30 outperforms the 5w-20 for the cranking test (ccs). Who knew? 🤷‍♂️
The winter rating isn't directly related to the operating viscosity. Or at least it doesn't have to be.
True. Just the nature of reading a label at face value and not understanding what each of the numbers represent. You can have a 0w-40 crank easier and be better “winter” performing than a 5w-20 conventional and it be drastically different rather then a small difference. That simply goes back obviously to a whole misunderstanding of the “winter” rating, but can include the base oil differences in the formulation of the two speaking to the degree of difference in their characteristics.
True. Just the nature of reading a label at face value and not understanding what each of the numbers represent. You can have a 0w-40 crank easier and be better “winter” performing than a 5w-20 conventional and it be drastically different. That simply goes back obviously to a whole misunderstanding of the “winter” rating.
It’s highly dependent on the temperature.
No.
