Mobil 1 ESP 0W30 is PAO/GTl/Ester/GRIII
Mobil 1 ESP 5W30 is GTL/GrIII
Mobil 1 Advanced Fuel Economy 0w30 is GrIII.
AFE was never robust oil. It was always shear prone.
ESP 0W30 from oil.ru:
The oil is declared as: ACEA C3; VW 504 00 / 507 00; MB-Approval 229.52; MB-Approval 229.51; MB-Approval 229.31; Porsche C30.
1) A pour point of -57°C is extremely low! This means you can safely use this oil not only in Siberia but also in the Far North. It's almost impossible for this oil to freeze in the crankcase. If you've got it in your engine and you notice the starter turning very slowly when cranking, it's more likely that your battery is frozen than the oil itself.
2) The base number is 8.7 mgKOH. Slightly higher than usual. Mobil clearly uses an ashless additive, which slightly increases the base number. It's supposed to be a medium-ash oil, but it has detergent and neutralizing properties, almost like a full-ash oil. Of course, our harsh operating conditions will still negate all of this. I'd say you can extend the drain interval with it; thanks to its synthetic base, this oil will forgive you a lot. But it's still better not to tempt fate and change it after 7,500 kilometers in a gasoline engine or after 10,000 kilometers in a diesel engine.
3) The viscosity characteristics are quite strong. The viscosity at 40 degrees Celsius is high. At 100 degrees Celsius, it's 12.21. By all indications, this is a thick, strong 0W-30. If you're afraid to use this oil and think that low viscosity can cause wear, let me reassure you: this is practically the thickest 0W-30 oil. Use it with confidence, whether in winter or summer!
4) Flash point = 243C. Extremely high. 0W-30 usually has worse flash points. The culprit of such good thermal stability is the synthetic GTL and PAO base oils. 5) NOACK
mass evaporation = 9.1%. This is evaporation at a temperature of 250C within one hour. A decent value for a zero grade. The oil shouldn't burn off much, if that's what it's used for. 6) The sulfur content is 0.197% - low. The oil contains a modern additive package and is generally sulfur-free. However, the sulfated ash content is slightly higher. According to the ACEA C3 standard, it should be < 0.8%. For some reason, I think there's an inaccuracy here (I'll ask the lab). In any case, there's nothing to worry about. The excess is not significant. 8) The Infineum additive package. It contains organic molybdenum to reduce friction. Boron as an ashless dispersant. It improves the interaction of the additives with the friction surfaces and carries away contaminants when draining the oil. It keeps them in suspension. Calcium as a detergent and neutralizing additive. And phosphorus plus zinc as an anti-wear additive (ZDDP ).
The IR spectrum (using MSDS ) indicates that the oil consists of GTL + PAO + esters + hydrocracking.
Conclusion: The parameters are all normal. Don't worry about the slightly elevated ash levels. They're minor. It doesn't affect speed. The oil's advantages are as follows. It consists mainly of PAO synthetics , esters, and GTL . That's why it has such a low pour point of -57°C. It has good thermal stability at high temperatures—low evaporation. It has a strong viscosity for a 0W-30 oil. The oil's only drawback is the price: 3,200 rubles for 4 liters. It's not cheap.
