If anything, that thin as piss 0W-20 or 5W-20 gets slung off the chain and that is what causes the wear.
That may be your perception but it is not even close to the facts. Modern oils are better than ever.
You know the back side of this argument. Hondas are manufactured in Japan. Been 5w-20 for 20 years in Japan. In Europe they concentrate on smog and the oil is formulated for that. So the OCI is different in Europe than Japan and US. Sure… one grade heavier is acceptable but the engine is not engineered to that viscosity. Modern engines are proven to last with 6 month OCI.If anything, that thin as piss 0W-20 or 5W-20 gets slung off the chain and that is what causes the wear. I am amazed at how folks buy the "use 0W-Whatever" because "that is what the engine was designed to use" mantra. Do research and you will find most engines in America that spec these 0W-whatever oils use thicker oils overseas. Our first Honda speced 5W-20 but the same engine in Europe and Austrailia speced various weights of oils much heavier than 5W-20. Same for my 2010 Scion XD. It specs a 0W-20 in America but many other viscosities are recommended for the overseas version.
0W-xx, 5W-xx, 10W-xx...etc is the WINTER rating, it's simply the oil's ability to meet to performance specifications for Cold Cranking Simulation (drag) and being able to pump at a temperature 5C lower.If anything, that thin as piss 0W-20 or 5W-20 gets slung off the chain and that is what causes the wear. I am amazed at how folks buy the "use 0W-Whatever" because "that is what the engine was designed to use" mantra. Do research and you will find most engines in America that spec these 0W-whatever oils use thicker oils overseas. Our first Honda speced 5W-20 but the same engine in Europe and Austrailia speced various weights of oils much heavier than 5W-20. Same for my 2010 Scion XD. It specs a 0W-20 in America but many other viscosities are recommended for the overseas version.
How does thinner oil work better to get sludge off of parts?If anything, that thin as piss 0W-20 or 5W-20 gets slung off the chain and that is what causes the wear.
Many are also proven to last with 1 year OCIs. Many vehicle manufacturers have a "xyz miles or 1 year, which ever comes first", statement about oil changes.Modern engines are proven to last with 6 month OCI.
How long ago did they start 1 year OCI’sMany are also proven to last with 1 year OCIs. Many vehicle manufacturers have a "xyz miles or 1 year, which ever comes first", statement about oil changes.
My 2002 Z06 owner's manual says one year or when the OLM says to change the oil ... which ever occurs first. Speced Mobil 1 5w30 full synthetic. So I'd say about 20 years or more. Also, Ford has had a similar statement in the OM for many years (at least 7-8).How long ago did they start 1 year OCI’s
Yeah, my SRT has the time stipulation as well, I just ignore it and change based on the OLM. I'm using a premium Euro lube, there's not a chance in hell that it's "used up" when the calendar magically hits a certain date.My 2002 Z06 owner's manual says one year or when the OLM says to change the oil ... which ever occurs first. So I'd say about 20 years or more. Also, Ford has had a similar statement in the OM for many years (at least 7-8).
From the 2002 Vette OM.
Thicker oil would result in more oil pressure from the pump. But keep in mind that all oil is pretty thick when cold, so during a cold start and the warm-up phase, there is more oil pressure going on in every engine.Liquids are generally considered incompressable aren't they. How would a thicker oil vs thinner oil change the pressure of the tensioner?
I believe it started with the introduction of so called “Intelligent Oils” I.e. oils that can sense when the earth has made one complete revolution around the sun, at which point it decides to degrade with rapid loss of viscosity and TBN resulting in increased wear and contaminant dropout.How long ago did they start 1 year OCI’s
Personally do not put miles on my car and like to do oil changes. All I can say is Mazda is 6 months.
None. The oil pump bypass will dump excess oil @ a set pressure no matter what viscosity is used.
I did nothing but LONG OCI's in my 2010 Focus. 15K-17.5K OCI's. No issues. Sold the car with 200K miles and my brother in law now has about 225K miles on it. The Mazda/Duratec burned up to a quart of oil every oil change. When I went to high grades the oil consumption went down to a quarter or half quart between changes. Less oil burning means my expensive catalytic converter(s) will last longer.
POINT: Why so much carbon with the Direct Injected engines that do not have port injectors like Ford or Toyota? The thin-ass oil seeps past the "low friction/low drag" valve stem seals onto the top of the intake valves. Just creating more issues to eek out a few tenth's of an MPG on a lab test bench is not worth the long term issues in my book.
How does thinner oil work better to get sludge off of parts?![]()
So thinner oil can pay its bills better? Not sure what you're getting at. You think thinner oil cleans better? I'd think the cleaning ability of any oil would be based on the additives, not the viscosity.The lower the viscosity, the higher the solvency. (usually)
