I don't post often, but i hear a lot of a thick or thin 30w. I realize that a 30 w has a range to fall between to be considered a 30w. I have talked with Mobil, Havoline and Castrol, and they all said the same thing. The oil is measured at 212f for the viscosity. If that temp is 213 or 211, (which i have seen the numbers) a 9.8 cst oil can be 9.8 at 212, but 10.5 at 211. Also, a 12.5 oil can be 9.8 at 213. Plus these numbers they tell you or post on their websites are averages. This doesn't mean you have exactly that vis in you car.
