High load operating points (blue triangles and green squares in the high load region in
Figure 5) are defined in this paper as the region where enrichment is observed. In this region, data cannot be collected with steady-state procedures due to the transient nature of the engine control, which is employed to protect the engine from excessively high temperatures, to avoid pre-ignition at low speed/high load, or to avoid knock at high speed/high load. The ECU avoids these damaging effects by transiently adjusting the engine control parameters, often at the expense of fuel consumption and efficiency, through control techniques such as spark retard and
fuel enrichment.
