Owen Lucas
$100 Site Donor 2023
- Joined
- Sep 5, 2021
- Messages
- 4,850
I'll be changing the oil soon and give it a very distant sniff. We shall see.Not sure if notorious fuel diluter.
Well mostly true in NA engines, but turbo engines under load typically map richer, especially normally lean burn turbos.Agree, but most that have the ability to knock have sensors to retard the timing and stop the knock.
It would be a curious finding for premium fuel to stop dilution given the reason that it happens in the first place, but stranger things have happened.
Does spark knock equal more fuel dilution?They also only stop the knock under operating conditions where knock detection is turned on, which is not 100% of the time.
Do some used oil analysis on the fleet. I missed doing it last time as I promised The Critic.I'll be changing the oil soon and give it a very distant sniff. We shall see.
OK, but that would mean they burn richer despite fuel octane choice, right?Well mostly true in NA engines, but turbo engines under load typically map richer, especially normally lean burn turbos.
Not necessarily, only if knock detected - which happens under the high load (high pressure) situations with lower rated fuels.OK, but that would mean they burn richer despite fuel octane choice, right?
If you have LSPI, you are probably only going to have it once. It tends to be devastating, which is why there has been so much work put in to avoiding it entirely. On the other hand, conventional pinging/spark knock, which is why engines have knock sensors, is controlled through ignition timing of course, but also through enrichment and injection timing with GDI. This is particularly true for TGDI engines where enrichment and injector timing enable compression ratios that aren't possible with port injection, let alone on regular fuel. If the amount of enrichment and injector timing can be influenced through using higher octane, using feedback from the knock sensor, then this can have a positive effect on reducing the amount of fuel that makes its way into the sump.Meh, perhaps only if the engine is knocking due to LSPI (and higher octane helps) and/or the engine is tuned to use premium--otherwise a waste.
I run premium 100% of the time in my Bronco, it still has dilution...
Truck i was running last week had just over 100k miles and 26,000 hrs. F550 flatbed.Mileage isn't a a good indicator of oil life for many anyhow.
Engine hours is better. Even better is a setup that calculates oil life.
Mileage may be fine for a setup running highway like a L48 long haul driver. Otherwise is doesn't account for idle or slow driving.
IE my work truck has about 8900hrs and 25k miles.
It's had about 35 oil changes. If I did 3000 miles, that's only about 8.
Yup, an IOLM that takes into account operating conditions is about as "good as it gets" for a predictive system, as hours don't account for operating temperature (or whether it gets up to it at all thanks to short tripping), how much fuel is being consumed, average load...etc. Going by miles is even worse as it doesn't factor in hours along with any of those factors.Mileage isn't a a good indicator of oil life for many anyhow.
No. OEM tunes are generally not setup for more fueling when spark knock is detected. If anyone wants to prove otherwise, they should post the tables from the ECU software. Otherwise, it is speculation at best.Does spark knock equal more fuel dilution?
Are you talking NA? Yes I agree. Or are you talking turbo engines? You need to make the distinction.No. OEM tunes are generally not setup for more fueling when spark knock is detected. If anyone wants to prove otherwise, they should post the tables from the ECU software. Otherwise, it is speculation at best.
3,000 miles is not science, it's literally the antithesis of science because it's predicated on absolutely no operating data.It's not talking points, its science over speculation.
Your interpretation of the warranty comment and mine are different.While that is true, at the same time Lake often says things that are not quite true. A recent video where he's talking about Mobil 1 0w40, he says the FS on the label means full synthetic but yet it actually stands for FULL SAPS. Big difference there. And in this video in question when they are talking about how the manufacturers are calling for longer oil change intervals being extended and all that needs to happen is for the engine to just get past the warranty period, that's total nonsense too. No manufacturer in their right mind would want their engines to be dying just shortly after the warranty is up. Nobody would buy their cars anymore. There are a few manufacturers out there whose reputation was built on having long lasting engines (Toyota, Honda, Volvo) and there is no way they want to sully that reputation with a bunch of dead engines.
Lake does have a lot of oil knowledge, but it's very odd that with all of his oil analysis expertise he still says that we need to do shorter oil change intervals. The data he's looking at on a daily basis proves otherwise.
it’s a whole lot easier to make a LOT of money selling $70-100 oil analysis when your overarching recommendation is “change it every 3k, AND MAKE SURE to send in another sample so we can make sure you’re not going to damage your engine!” Just another shock jock.Lake does have a lot of oil knowledge, but it's very odd that with all of his oil analysis expertise he still says that we need to do shorter oil change intervals. The data he's looking at on a daily basis proves otherwise.
Haven’t seen this in any of the Nissan VQ engines we’ve tuned, NA and turbo.Are you talking NA? Yes I agree. Or are you talking turbo engines? You need to make the distinction.
I don't have tables. I think you knew that.
I know for a fact Volvo did this for years in their turbo engines. Does Honda do this? I don't know for sure. Not sure how to find out. You probably could and I trust you.
