Hybrid Oil Change Intervals (OCI)
Fuel dilution isn't ideal, but I skeptical that it is as big of an issue as people are making it out to be. As long as the wear remains controlled, the fuel doesn't cause imminent issues.
Agree. If it’s miscible in the oil and affecting viscosity that’s one thing. I have heard claims that it “harms” the oil but I can’t say that I’ve ever seen that chemically substantiated.
Hybrids are best at saving fuel. Not extending oil drain intervals. I do 5,000 miles oil changes on the Sienna Hybrid.
Same for me and our Sienna. During our IA winter, I would find white goo on the bottom of the oil cap. Thankfully that is not happening now that we are warm again, but that goo tells me the oil needs to be changed more regularly than I would have assumed, but I could go a little longer in the summer.
So, maybe my Spring change is 4000 miles and My summer is 6000 miles? I'll stick to 5000 to keep it simple. I do know, however, I will not follow the Toyota recommended 10,000 miles.
One anecdotal data point:
We own a 2023 Hyundai Elantra Hybrid. The engine is the Kappa 1.6 Liter direct-injected 4-cylinder. It just turned 35k, seeing 5k OCI's.
I've used Mobil 1 Hybrid or Valvoline Hybrid 0w-20 (used their 5w-30 for one OCI). Typical commute is 16 miles over rural rolling hills to the railway station & back with short errand trips on weekends. When I drive it, I tend to try to maximize MPG (I can consistently hit ~50MPG, minimizing the ICE-wife is more spirited in driving, about a 60/40 sporty/staid split per OCI). No oil loss between changes.
I originally had 3 concerns for this engine- fuel dilution, water dilution, and valve carbon build-up. UOA reflects neither of the first two for each change. I'd hazard a guess that my choice of oil has little to no impact on the latter, given the lack of gasoline passing over the valves. I've used CRC Industries' CRC GDI IVD® Intake Valve & Turbo Cleaner every 10k, and the scope through the throttle body looks good so far. I'll take the intake manifold off at 50k for a closer inspection and walnut blast if needed.
So far, this maintained engine has seen no need to shorten OCI intervals.
I run 10 k intervals in my Corolla cross hybrid. Almost 55k on it not an issue. I drive 600+ miles a week so I usually feel 10 k happens to fast. Typical drive is start and drive 56-60 miles shut down and do it again next time it starts. Definitely gets warmup up every time.
I would do the same if I drove the miles you do as quickly as you do.
I have no proof, but in my mind, my F150 hybrid seems like it would be harder on the oil. Simply because it really struggles to get the oil up to operating temps during colder weather. Couple that with the engine stopping and starting a ton more leads me to stick with 5k oil changes, even though that ends up being only around 3000 miles of the ICE actually running. Even now with the temps warming it will just barely getting to over 160 degrees after my 14 mile drive to work.
We do tow a 6600# travel trailer about once a month, so the truck does get a chance to get nice and hot on a fairly regular basis, but all of the hybrid running has got to take a toll on things.
My wife’s ecoboost plug in hybrid does about 3200 ICE miles during a 5k trip. Oil wreaks of fuel even with 80 mile round trip all hwy to work 3x week.
Probably won’t go over 5-6k total OCI in it.
Do you have the UOA posted somewhere?
