Quote:
So what are the advantages that conventional oils have over synthetics, other than lower initial purchase price?
The question is why spend more $$ when in the end you do not get any benefit?
I've NEVER had a sludged motor running conventional nor has any of my family.
I've had many engines make 200k plus miles and are going fine. I've got one with over 300k and its fine. All pass smog, run perfect and show no problems.
As far as your improved MPG, I have tried syn for a few oil changes in MANY motors and I 've never seen any improvement.
I've posted UOAs with syn and conventional in the same car here. Have you?
(give you a hint, the conventional uoa was better in many engines)
I've discussed MPG and cleanness findings in engines that I've owned. Have you?
I've cut open clean unsludged oil filters from many engines here using conventional oil. Have you?
All I've seen is you pushing syn oil in 99% of your posts. And most of those one brand. I've never said any one brand is the best because thats not true.
I came to BITOG to share FACTS.
Not marketing . Been doing that for over 4 years.
And I care about my cars and engines as much as the other person. I also care about the bottom line. I NEED my engines to last since I drive 30k miles a year.
As I've said in the past;
If your manual states you NEED syn oil, you have to run it.
If you WANT to run it, thats fine.
Just don't think that your engine is going to last longer because your running it. Because there are MILLIONS of cars that are luckly to see oil changes every year that are running fine. And they last a long time.
Any BITOG person is going to change their oil in a timely fashion.
ANY rated oil for their car is going to work.
I see Syn (and use syn, even buy the brand you sell
) for areas like transmissions, diffs and engines that REQUIRE it. Or long OCIs.
But, your OCI will have to be VERY long to keep the cost in line with onsale oils. (
my cost for a 5k oci including a filter is under $5 )
My 1986 jetta just passed 300k with many of those changes. Still passes dyno smog with ease. Never had a injector off. Never had a single problem with it.
Thats with SG,SH and yesterdays oils. And FRAM filters!
How does that happen??
How much do you charge for a single qt of oil?
(this post should get some replies...)
Take care, Bill
