The "M-word"
Lets deal with facts:
Mobil is big
Mobil IS NOT THE BEST OIL MONEY CAN BUY
Is there better oils out there for less money? yes.
Is there worse oils out there for more money? yes.
Mobil is an option in many options. Many do not choose the Mobil 1 option.
If everyone thought the same on these topics, we would not have this forum.
Originally Posted By: rg200amp
It takes YEARS to find labs, contract labs, set up the tests, test, research, test, research, compile the results, set up the proposed reports, pass it with the marketing teams, the law teams, the board of directors, ect. . . .
I was under the impression that Ashland, like any other significant oil company, had its own labs, had certification labs lined up, and so on.
So what you're telling us is that they need years to run simple standard API certifications on motor oil, and this is why you trust them?
That certainly wouldn't put me in line with money in hand to procure some of their products.
If the higher Fe #'s generally found with Mobil 1 UOA's are not from wear what are they from? If its something in their mfg or packaging process and iron is harmful to an engine then why not remove it before bottling the product? Granted I'm no expert on UOA's. Maybe they can't determine how much an engine is wearing, still it is a number that a lot of people who do know how to read them seem to always point out. Pablo is correct in saying Mobil 1 seems to be in the middle of the pack, and for the price they charge they should be a leader of the pack in quality, not volume. To all members: Spend your money anyway you like after all it's your money.
+1
Which Mobil is not the best oil money can buy in what category?
Air-cooled motorcycles?
Sport bikes?
Diesels?
Gasoline-powered automobiles?
Piston-engined aircraft?
Jet-powered aircraft?
And, if Mobil is not, who precisely is in each of these categories?
Originally Posted By: buster
Ashland Q&A from JobbersWorld - It says "average" of 180 microns, and talks about "samples" not sample. The letter also says "over the past couple of years, Valvoline conducted a number of tests" not test.
http://jobbersworld.com/valvolinesletter.htm
I'm very confident they were caught.
I was reading the letter not the Q&A sheet. I see that on there now.
It does not list the independent lab, whether they are certified to run the API test, or any information about the batch tested either though......
If you trust any company, let alone a oil company your a fool.
Yes it takes A LONG time to make that kind of statement against the worlds largest oil company if you value yours.
There not going to use there labs. That would be a biased lab result if they used there own.
No I do not use Ashlands products nor do I use Mobil 1.
I am a fan of Pennzoil Products. I am useing Redline right now.
So since I have no side when comparing these two companies, I will again say props to Ashland as of now.
Sport bikes?
Diesels?
All of the above.
And if you really know anything about Oil, you would know NOT ONE BRAND oil is best for every ones application.
UOA's sample a NARROW spectrum of particulate size. It is very possible that the average Fe wear produced by this particular grade of oil is simply higher within that size-range and lower outside. We do not know. We also do not know if other oils have HIGHER Fe wear outside of this spectrum and lower within. They are NOT a tool designed to evaluate wear!
This is why tear-down testing is performed. To evaluate wear. BuickGN had some great UOA's and some horrible wear. So what did the UOA's tell him? NOTHING other than his oil didn't have coolant in it
My understanding of what a UOA provides, based on Doug's results is this:
AVERAGE oil contamination in terms of wear metals, fuel dilution, ash load and other items that can indicate external contamination sources like coolant leaks. It gives you a useful indication of remaining oil life and how easy or hard the engine is on oil.
Great tool to use to determine your maximum OCI or if you have fuel dilution or coolant problems.
Not a great tool to determine how your engine is wearing.
Sport bikes?
Diesels?
All of the above.
I said that several pages back:
There are a number of people on here who have found SUPERIOR performance using a particular product by utilizing tear-down testing. This is valid. Redline has been one of those products for one member. AMSOIL has been one of those products for another. I believe generic 20w50 has been the same for another member.
The definition of "better" needs to have the operating situation and the means of evaluation considered to construe any true meaning. There is no single oil or brand that is "better" in all areas.
Actually they did use their own lab.
Then apparently "validated" their results using a 3rd party lab, who has remained unnamed.
So, this Mobil 1 bashing based on some pretty vague "evidence" will be concluding?
Yes, but a new car shows high wear numbers on a UOA, and a broken in car with quality oil and good OCI shows good wear numbers on UOAs.
When theres an issue like alot of dirt getting in the oil like SI, wear numbers go up. SO yes a tear down is the best way. But I do think a UOA can tell something. Even if it only shows a "NARROW spectrum of particulate size" I would want that spectrum along with rest of it at its lowest point. So if that one spectrum is low, I would trust so is the rest.
TO my understanding, the bigger Iron particals can not be seen in a UOA. SO if the smaller partical count is lower with one oil, I would trust the larger particals that are not shown on a UOA would be lower as well.
I am not bashing any company. I welcome any and all view points on the data we have infront of us.
I have never said Mobil is in the wrong, or they are a bad company.
Because the NARROW spectrum sample is considered representative of the AVERAGE degree of contamination.
The thing is, it is possible that there are fewer larger particles generated by the M1 5w30 and simply a higher "signature" within the range that happens to coincide with what is sampled in the UOA, giving you a false "high", when none exists. Whereas another oil has more wear over a broader range, but the sampled range would show less contamination.
This is why an actual tear-down with REAL measurements is the best means of evaluation. Because we really DO NOT KNOW. It is all speculation.
Now Doug actually provided REAL evidence, using 150ppm of iron as his condemnation limit on his UOA's, and did a tear down at 1.2 million Km to find no real wear! The engine was reassembled and is STILL in service now with something like 2.5 million Km on it.
So what exactly did that 150ppm of Fe in the UOA tell him other than a contamination level?
Generally.
"Generally" means "not always".
Elemental analysis involves a logical process called "inference", which means "the act of passing from one proposition, statement, or judgment considered as true to another whose truth is believed to follow from that of the former".
We infer from the increase in iron in a used oil sample that wear of ferrous metals is taking place.
However, inference is not the same as direct evidence.
There are anomalies in elemental analysis that do *not* correlate to the assumed inferred conclusion.
That is why, in order to interpret elemental analysis, you need:
- sequential elemental analyses
- careful and complete documentation of ALL variables
- preferably the aid of an expert in elemental oil analysis
Generally.
Theres no "generally"
A new engine shows more wear than a broken in engine in good working order with good oil and OCI.
Yes we "infer from the increase in iron in a used oil sample that wear of ferrous metals is taking place"
Because little people do not sneek around and put iron shavings into our oil sump while we sleep. There are only X amount of ways to get Iron into the oil sump. Either its in the oil new, or Iron particals are "worn" off of the internal parts of the engine.
Plenty of us, search back a few years.........Then do some comparisons to Amsoil or PP to name a few.
"... in the big lie there is always a certain force of credibility; because the broad masses of a nation are always more easily corrupted in the deeper strata of their emotional nature than consciously or voluntarily; and thus in the primitive simplicity of their minds they more readily fall victims to the big lie than the small lie, since they themselves often tell small lies in little matters but would be ashamed to resort to large-scale falsehoods. It would never come into their heads to fabricate colossal untruths, and they would not believe that others could have the impudence to distort the truth so infamously. Even though the facts which prove this to be so may be brought clearly to their minds, they will still doubt and waver and will continue to think that there may be some other explanation. For the grossly impudent lie always leaves traces behind it, even after it has been nailed down, a fact which is known to all expert liars in this world and to all who conspire together in the art of lying."
—Adolf Hitler , Mein Kampf, vol. I, ch. X
It helps, apparently, to have little or no actual experience in the world of lubrication and automotive maintenance.
Those of us with experience know better.
Nice, you keep using Mobil 1, its your money. I'll spend mine on another brand. I won't fight for any company other than my own or one I believe in, I don't believe in Mobil anymore.
